Mini Jet build 1980 C jet with 700cc motor and mini berk 6j
Results 1 to 14 of 65
    Senior Member bartel's Avatar
    Mar 2010
    Default Mini Jet build 1980 C jet with 700cc motor and mini berk 6j
    So instead of highjacking lilwake's thread i decided to do some pics of my build on this thread
    This is the boat when i brought it home
    Had to cut it apart to cut out the rot
    Fixing some holes and cracks inthe bottom
    The two halves
    the area i had to work with
    2006 22ft Placecraft 496 Mag
    Mar 2010
    I tried to get creative with my work space but this was more trouble than it was worth
    fitting the top to the bottom
    glassing the pieces together
    building the template for the window
    a little bit of block sanding
    Mar 2010
    first motor test fit
    found this gas tank that almost fits. just got to trim it up a little bit
    front view
    i put two shelves on both sides of the bilge to mount things to
    and that is where she sits now. hope to fit that gas tank this weekend and throw a coat of gelcoat down on the inside
    Mar 2010
    mini berk
    Aug 2012
    Portland Or
    Such a cool boat! I dig the hull design! I can't wait to see it all done. I swear I read on Lil wakes thread that you're going to do a wrap on it after paint???? What kind of wrap are you gonna do??? I have a half wrap on my dodge pickup and i love it! I plan on wrapping my mini to match it.
    Cougar Cub mini cat 10
    complete overhaul in progress / inboard jet conversion
    Mar 2010
    i am just going to brush on some gelcoat to give the wrap something to stick to. the wrap will last longer if it has a hard glossy surface to stick to. sanded fiberglass is not the best for sticking a wrap on. so two coats of gel coat should help. as far as a color scheme i am not sure yet. something up to date a racey...
    Aug 2012
    Portland Or
    how much fuel are you planning on having on board???
    Mar 2010
    as much as will fit. I am using that square tank but i have to cut it down to fit where i want it. i wont know exactly how many gallons it holds till it is done but i am expecting 8ish
    Aug 2012
    Portland Or
    forgive me for a dumb question, but with the fuel tank on the one side, when it's full, are you at all worried about it leaning in the water to one side??
    Junior Member dragracr's Avatar
    Jun 2012
    Cool project for sure. Yea i agree i would cut the tank you have in half and put one on each side... Your project, im just thinking out loud.
    Mar 2010
    I figure if its full of gas it will most likely have a driver in it so i am trying to get some of the weight to the other side. If i balance the weight then when i am in it it will lean to the driver side. i figure 8 gallons of gas will weight about 50 lbs and not be that big of a deal. it will probably still lean toward my side with the fuel tank on one side. when i get out it mmight lean toward the passenger side but then i dont really care.
    Aug 2012
    Portland Or
    the more i stare at your mini.. i love the hull you are starting with. so jelous!!
    Mar 2010
    Ya I think when it's done it is going to have a very cool and unique look to it! I like your power plant and jet set up!
    Man I'd love to see this with like a 4.3l v6
