speed coat or not?
Results 1 to 13 of 13
speed coat or not?
    Aug 2009
    Default speed coat or not?
    well my gullwing is upside down and in primer.question is anyone ever prove or disprove speed coat as a posative or negative affect on speed or handling
    Placentia, CA
    Put the primer on with a roller to get a stipple effect like a golf ball and then speed coat, it works! If it's good enough for Billy B, just sayin'.
    steveo143 AKA DiMarco 21 II
    Default Tie downs....
    AND, tie it down really good...... That stuff is so slick the boat will slide all over the trailer....Beentheredonethat..............
    Ray
    LOUD BOATS SAVE LIVES
    I think the jury is still out on this ?????
    S CP
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    S CP
    We'll ask the guys with good running boats that actually boat darrin jr
    Quote Originally Posted by 78CoLeBBF View Post
    ....I guess he's been out of the loop for a while:
    but back when he won 9 Championships over a 12 year period ........ the speed coats slowed him down vs his standard bottom prep.
    I will look for up-dated info. Thanks.
    S CP
    Aug 2009
    arg...my trigger finger is startn to itch. or maybe my roller finger
    Senior Member Green w Envy's Avatar
    Edmonds, Wa
    S CP
    Jon, isnt that Rons Old ride? Second to none?
    Darin
    Golden Shores,AZ
    S CP
    hmm last i heard that boat was using a graphite finish with a bit more prep and finish work than others. Maybe you graphs from signies boat show other finishes?
    interesting......
    if you take the total sq ft of surface area that's touching the water at speed ( probably less than 6 sq ft) if would be very interesting to see if Speed Coat vs Ron's old prep work ( flat black paint with a light sanding) makes any difference at all.
    S CP
    Golden Shores,AZ
    interesting......
    S CP
    whats the resistance differance between flat black paint with some sanding and graphite with some sanding?
    SoCal
    All I know is the bottom of my boat has speed coat and I can slide it around on the trailer with very little effort.
    You all mentioned sqft of surface contact, maybe it depends on the type of racing. Might be a bigger improvement on a circle boat than a drag boat?
    [email protected]
    BLOWN GAS FLAT TO THE RAMP
    REST IN PEACE MY FRIEND
    I don't get any Barnacle build up in the speed coat areas, most all my wet area is sanded, and the last few feet of the sponsons, and 7 feet of the center pod are speed coated.
