Water Lubed Dominator?
    Aug 2012
    Default Water Lubed Dominator?
    One diagram that I've found on this site says that I should have a grease fitting here. I've also come across discussion in the forum that claim some Dominator pumps are water lubed.....is this one?
    Quote Originally Posted by 1320 View Post
    Would appear to be water lubed from the photo, with some effort including bowl removal and a sleeve kit it could be converted to grease lube but not really neccesary the time to consider that would be during an overhaul Tom
    Aug 2012
    Thanks Tom
    Senior Member SBS933's Avatar
    Jun 2012
    My Dominator is water lubed, but i do have a grease zurk inside the pump center of that plate.
