Jet Boat cooling water strainer/filter???
Results 1 to 6 of 6
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    Default Jet Boat cooling water strainer/filter???
    Looking into installing a filter/strainer on my mild build 468, AT pump with A impeller, no water regulator or thermostat on water supply.
    Here in Alabama the lakes have debris like leaves, twigs, etc....my header lines get clogged from time to time and I have to clean them. And I am sure some of this debris finds its way and hides out in the engine....
    Looking for an economical solution. Not knowing how much water pressure is generated in the cooling lines from the pump, I would like to know what filters/strainer you may be running. I have seen a wide variety discussed here ranging from $9 to $600+.
    What is a good dependable "middle of the road" filter/strainer?
    TIA for your thoughts...
    Morgan Hill
    Perko makes some really nice ones.
    I have been using them for years with very few complaints.
    These are rebuild able and hold a lot of crap before they need to be cleaned. Be sure to use a pressure relief valve before the strainer to ensure a "tattle tale" that there is an issue...
    Perko 493 Series Intake Water Strainer 3/4 Pipe - Overton's
    GT
    Apr 2011
    Sweet Home Alabama
    Thanks! This is good info
    What info you got on "relief valve" Pressure rating?
    Based on the lack of replies to this thread, apparently there are not many jet boaters running strainers....
    Jan 2012
    St. Louis, MO
    Quote Originally Posted by SNiC View Post
    I'm using a simple bronze strainer. P/N 43935K25 from McMaster-Carr. As GT Jets alludes, you need to have some indication of if/when it plugs up. I monitor water pressure.....
    Junior Member 71rcb's Avatar
    SNiC -- where are you at in AL? I am temporarily displaced to Montgomery ... been to the Al river and Lake Martin both pretty nice ... although Lake Martin was nutz over Labor Day ... not in a good Havasu way but in too many roll bar boats making a mess of the lake way.
    Cheers
    Corey
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    i have a perko i will sell.
    It's not that i don't care, I just dont give a sh!t!
