WJ shakin' and slippin'
    Monroe, WA
    Question WJ shakin' and slippin'
    I pulled the WJ out of my Spectra 18 cuz the seal was out, filling the boat with water. I had noticed some slipping and vibration on my last run, but found a big chunk of grass in the impeller so I figured that was it. Now after new seals, bearing and wear ring it STILL shakes and cavitates!!! The leak is gone (one small win) but it still feels like there is something in the impeller! I pulled the cover and can't find anything in it, really has me scratching my head. Sound familier to anyone?? I have a loader on it and I'm pretty sure it hangs down too much, but it's been on there since before (when it still worked). At wot it seems to pull out of it and spins 4900. I know it seems like there is something in there... just can't find it and I just had it all apart!
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Jun 2011
    spokane, wa
    Mal,
    Are you sure all the edges of the impeller are straight?
    Monroe, WA
    It isn't perfect by any means, but it is still the way I had it back when it worked. I don't know....
    I'm going to yard it out and look it over real good. I'll let you know if I find something in it.
    Malcolm
    75 Spectra 18
    Monroe, WA
    I did find some twigs and grass in it. I know they weren't there when I checked it at the beach so I think it showed up at the ramp on the way out. We'll see how it runs at MarDon!!
    Malcolm
    75 Spectra 18
