Roost not high enough
Results 1 to 12 of 12
    Yucaipa, California
    Default Roost not high enough
    i have the boat in my sig...i know the 12je is limited in place diverter roost because the throttle cable and directional cable have to bend..but how can i get more height out of it?
    1992 Eliminator Daytona 21'
    Senior Member cave's Avatar
    Mesa, AZ
    If its a 2 piece bowl you can insert wedges from 1° to 4°. That will get it up there. You may end up with a nasty bounce.
    Takin it home
    Southwest corner AR
    If no split bowl you can do the Place Diverter trim to get some more up trim! Smoken lowrider SS has some good pix. in another thread. WT
    Coby
    Senior Member koyota93's Avatar
    Orange County, CA
    The JE doesn't have a split bowl. You can find one from a JG pump and add a wedge. I was thinking about doing that to my JE and adding a droop snoot, too. If you add a snoot you will be required to reconfigure your steering to those similar in the set back pump set ups. If you add the snoot and reconfigure the cable, your JE diverter will not work. If you add a snoot and try to use the factory JE steering to make you JE diverter work, it looks like a pain in the A$$. I haven't bought a diverter yet so I can go either way. You may want to contact Tom at JBP for more questions, he's the one that helped me out.
    Yucaipa, California
    Default thanks
    thanks for the input....i really didn't want to go the extra mile and put a split bowl on...especially if it won't really help the performance of the boat. The boat is very heavy and somewhat low on power...i just wanted to look a little cooler! hahah. I'll keep all of that in mind for the future though! thanks!
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    You could always go with the Berkeley Jet-o-vator rather than the Place Diverter, and save some money.
    Wags
    somwhat low on power ????????????????????/
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Heavy boat?
    How heavy, how big?
Name:	'08 boat pictures 001.jpg
ID:	14524   Click image for larger version.
Name:	'08 boat pictures 003.jpg
ID:	14525   Click image for larger version.
Name:	'08 boat pictures 036.jpg
ID:	14526   Click image for larger version.
Name:	'08 boat pictures 066.jpg
ID:	14527   Click image for larger version.
Name:	'08 boat pictures 096.jpg
    Q.C./Big River
    Quote Originally Posted by koyota93 View Post
    If you would like to put a diverter on your JE with a snoot pm me and I will let you know how to do it. I have a div, droop, and wedge and my roost is pretty nice.
    Junior Member Army Navy's Avatar
    I put a split bowl on my JE, its much more adjustable with wedges and so on. Look for a bowl in spam or ebay.
    Orange County, CA
    I would love to do it, but probably not till next season. Just blew the motor, so the budget goes to rebuilding that.
    hunt down kenny(devilman) he's got some nice pics of the divertor mod to get another up notch outta it. just be carefull and don't grind to much off it.
