Is it o.k.
Results 1 to 7 of 7
Is it o.k.
    Senior Member SBS933's Avatar
    Jun 2012
    Default Is it o.k.
    I just finished installing new wood and carpet on the trailer skirts, next are the bunks. The carpet is O.K. on them, is there any reason I can't re-carpet over them, for a little more padding or is it a bad idea
    The Right Coast/SE-PA
    Carpeting over carpet will hold the moisture, accelerate rot in both the bunk and carpet.
    I use a heavy nap indoor/outdoor (almost like a berber) carpet with stainless staples > last a loooooong time too!
    Jun 2012
    Thanks Bro, It's off with the Old and on with the New.
    I went over mine but the first layer was only two years old over new out door wood. Still looking good after 6+ years.
    Made In The Shade
    Custom Window Tinting
    Jun 2012
    HHMM Thinking now, mine isn't that old either.
    MD
    if you drive on No
    if you float on you will be fine
    Jun 2012
    if you drive on No
    I float on so thats not a problem, I'll get the boat off the trailer and check out the situation. Probably gonna remove and replace. I don't want to change the loading process.
