single tunnel ram question
Results 1 to 11 of 11
    use a BBC to pull a BBC devanwon's Avatar
    portland oregon
    Default single tunnel ram question
    I have a 455 olds .030 over, 512 lift cam with top end to match ,I have a single offy tunnel ram running a 750 demon carb. IS THIS ENGOUH carb for the motor, dont want to burn a hole in the piston. Thanks!
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    I wouldn't run a single tunnel ram. Equal fuel distribution to all cylinders sucks.
    Race
    portland oregon
    I have a full mallory electronic setup also, just to let you guys know all the info. thanks for any help, its greatly apprecated
    Mission Viejo
    Here's a thread that was rolling a couple of weeks on it. Lots of good advice. Good luck!
    http://www.performanceboats.com//showthread.php?t=9380
    Race
    Quote Originally Posted by devanwon View Post
    My old Southwind with a 460 Ford and wet logs ran a 750 for a while. You didn't mention rather or not you had headers.
    A 455" engine at 5,000 rpm's would use approx 658 cfm's.
    Sleeper CP
    portland oregon
    sorry I have wet logs on the boat, not sure if that makes a difference but sounds like my 750 will be ok.
    portland oregon
    would you guys fatten up the jets or just leave it, the demon carbs tend to run a little higher than rated cfm from what I am told.
    Newton Ks.
    Plenty of carb, if you don't have mixture distribution problems (which tend to PLAGUE single 4-barrel TR setups). Good luck.
    H.L. Mencken
    Senior Member OverKill's Avatar
    I had a single carb. TR on my 468. My best setup was an 850 Holley double pumper with Mechanical Secondaries. Don't use a Vacume Secondary carb. The signal was not good and it just didn't run right. I also put on a 1.50 Tappered Spacer from Wilson Manifolds and it ran even better with no leaness issues.
    So IMO with a Single carb. TR use an 850 Holley DP with Mechanical Secondaries with a 1.50 Wilson Manifolds Tappered Spacer. That combo should be just right and you should never have a problem.
    here is a pic of the setup
    Santa Clarita
    I wouldnt run a single carb tunnel ram for the simple fact that all my friends would laugh at me.
    I just loved the challenge of getting one to run right. I ran 72 mph, now it's time to move on to other things. I was laughed at a bit though LOL. Now it's Nirtous and a new manifold, I went with the Weiand Team G. Can't wait till Big River this weekend to see how it will run. I'll fill you all in later.
    OverKill
