Motor mounts question
Results 1 to 3 of 3
    DEG
    DEG is offline
    Senior Member DEG's Avatar
    Mar 2012
    Default Motor mounts question
    Are 4 point mounts all that much better then 3? In a jet.. I was thinking about switching it over to a 4 or beefing up the 3?
    Aug 2010
    i swapped from a 3 point to a 4. i think it was a worthwhile upgrade. taking the motor in/out was a pain to get everything lined up with the 3 point, which i pull the motor out for every oil change. plus without the huge bellhousing in the rear and mounts in the middle i have a ton of room, its easier to clean the bilge and i ended up tucking the fuel pump up where they used to be. with the plates and angle sandwiching the stringers it just seems like a lot better setup. seemed to help with vibrations as well.
    Shell Knob, MO
    Yes!
    Duane HTP
