Boat won't start..........
Results 1 to 2 of 2
    Default Boat won't start..........
    well that was interesting:
    S CP
    Can of Carb cleaner, then wd-40 and some grease all was good and some silicone .
    did a leak down test... Cold 5 were leaking 3-4%, 1- 8%, 1-10%, 1-16%
    ran it this morning after fixing the starter. the one leaking 16% went to 4%, the 10% dropped to 3%. All is good.
    ran the valves.... adjusted 3 out of 16. Not bad after better than 140 miles worth of river time.
    Yucaipa, California
    Holy crap sleeper...stop using that thing to pull skiers in the salton sea!
    1992 Eliminator Daytona 21'
