Grinding on logs
Results 1 to 12 of 12
Grinding on logs
    Default Grinding on logs
    Has anyone ever ground out a small area on nicson snails to replace the studs with bolts? Anyone have any opinions as to how much could be ground out?
    Ladera Ranch
    Quote Originally Posted by Mr Plow View Post
    Use a stud. Thread it into the end of the log, put the snail on and then nut it with a lock washer or a nyloc.
    No stud, hence the the question, has anyone replaced a stud with a bolt.
    Not sure what the casting thickness is (to allow for grinding) and if you dont have studs you could trim the heads off the allens and make them easily Tom
    I hadnt even thought about grinding on the head of the bolt to get it by. Thanks Tom!! Some days keeping it simple eludes me.
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    Why not open up the mounting hole, where the bolt cahn be slid in at an angle? it shouldnt effect the mating surface.
    2011 Rouse Performance 19'
    WFL Crew
    If your allens are long enough, doublle nut the shank, clamp the nuts in a vice and sawzall the heads off then chase the threads and viola`
    Santa Clarita
    I don't think Tom was telling you to grind the head of the bolt to clearance it. He said if you don't have studs, you can grind the head off those bolts to make studs.
    Why not just run studs instead of trying to grind on everything? Seems you are just making a bunch of work for nothing.
    Quote Originally Posted by Alter Ego View Post
    Snails need as much mounting area as possible. The gaskets are prone to crack where the studs are and if you remove more material....might cause a leak. Just use studs/nuts,high temp rtv and flat washers. Jim Brock on this site will sell you custom made gaskets that are a bit more durable than the green ones.
    Made In The Shade
    Custom Window Tinting
    Good clarification MP Thanks , might be if memory serves Plow lives in the Canadain countryside may have limited resources for stainless stud stock ..
    Close Tom, North Dakota.
    Studs are going to be an issue because with the stud in the manifold, I can not get the snail over the stud as the oil filter mount is in the way. Believe me I am not trying to make work for myself. I am trying to make work what I have in my possession.
    I am just going to pull the manifold and put the snail on, off the block and then put the manifold back on.
