[Question] 460 Ford dipstick tube complications
Results 1 to 7 of 7
    Sep 2012
    Default 460 Ford dipstick tube complications
    I'm new to the site. I have a 76 Hawaiian Jetboat with a 460. A month ago while out on the water I realized my oil pan was full of water so I pulled the motor thinking I had blown a headgasket but it turned out that corrosion had worn a hole in my timing chain cover. While I had the motor out I figured I would clean up the motor, paint it, get new intake, have the heads rebuilt, got a new timing chain cover and pressed a new dipstick tube into the timing chain cover. Needless to say I took it to the dock the 1st time and it runs great however there is water spewing around my dipsick tube and again slowly filling my pan with water. The higher the RPM is the faster the water spews out. I have no idea what to do any help would be greatly appreciated.
ID:	178945   Click image for larger version.
    California
    Quote Originally Posted by Ronix View Post
    Are you running the steel separator plate between the Water inlet plate and the timing cover? This is the same piece a car type water pump would have, those Berkeley Inlet Covers are the only ones that need them, this seals off the water ports from the rest of the cover including the dipstick area.
    Sep 2012
    Josh I am not and have never had one in there do you think if i put one in that would take care of my problem? the wife named my boat Saturday killer lol....
    California
    I belive that plate with the right gaskets and a little sealer will fix the problem you are experiencing
    Oct 2011
    Your cover is odd, it didn't have one like this?
    I never hit bottom. 79Challenger's Avatar
    Quote Originally Posted by rpm0414 View Post
    I have one just like that. Not as pretty, but if Your interested, name a price and its Yours. We just pulled a 460 from a boat we are redoing.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    O fix would be plug the dipstick tube, put a stick in the pan, or i would pull the front cover off make sure its flat or atleast close and generously silicone and gasket both sides, may need to weld up the corroded area too.
