intakes
Results 1 to 14 of 23
intakes
    Senior Member lupo1904's Avatar
    Feb 2011
    Default intakes
    I have a berkley intake and i need to remove it due to leaks, also the gullwing gurus told me it is at the wrong angle. Well what i want to know is the difference between low profile intakes and the berkely intakes. Is it worth spending the loot on a low pro vs just setting my old one back in at the proper angle for my set up?
    Mar 2010
    Clarksville, TN
    What are you gonna set it back at??
    Feb 2011
    If i remember right im at 2* and was told it needs to be at 4*. Does that sound right?
    Are you gonna wait till after the event later this month?
    Made In The Shade
    Custom Window Tinting
    Feb 2011
    Yes Sir Don
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by lupo1904 View Post
    I've herd 4 and 4.5.
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Give Chris at b1 racing a call. He can point you in the right direction.
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    B1 Racing cs19's Avatar
    Basically the only way a lo pro is going to work (with a wetsump pan) is if you are willing to run the engine fwd enough so the pan and flywheel cover is forward of the intake itself, lo pro intake is very low and therefor the engine must be low. No issues with a drysump pan.
    For a non race river deal I'd stick with a 4 degree and just do a nice clean detailed install with a maximum setback on it . Don't cut clear thru the transom but push the intake back far enough so the flange almost hits the transom. Set it at 4.2.
    B1Racing.net
    Feb 2011
    Thanks for the info chris and it was nice meeting you at the bay fair.
    Feb 2011
    ok i got my intake out and almost all cleaned up,can someone tell me how much sea going epoxy i will need? will a quart do it?
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    Any pics of your project?
    Feb 2011
    Sure
    Feb 2011
    D
    Feb 2011
    F
