rogers sub floor ?
Results 1 to 13 of 13
rogers sub floor ?
    Maple Ridge B.C. Canada
    Default rogers sub floor ?
    I have my 76 rogers gutted,motor ,jet, seats, carpet all out. Wondering how I can tell if I have a big wet sponge under my floor other than just cutting it apart. I don't have the means to weigh the boat ?
    Is it a wood floor? If you can see it if it is wet is is usually black if it is wet. Also any delamination?
    Aug 2010
    tap around with a hammer or something hard. you can easily tell soft wood from hard wood by the thud... and if the hammer goes through...
    Drill a hole in the bulk head where it meets the bottom of the hull with a 3/8 or so bit. Raise the nose up and see if any water comes running out. Usually if there's water, there's a lot of water, so you'll know.
    its wood sealed with cloth & resin. I think its original. I tapped on it & it sounded ok .doesn't even seem soft. I'm more concerned about if theres foam under it & if the foams waterlogged. I read another thread bout a couple hundred pounds under there
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    If you're talking about foam under the floor on the Rogers, i've removed 3 subfloors and none of them had foam under them.
    All foam was in the bow compartment
    Looks like we were typing at the same time
    Valley Center Ca
    Roger sealed these up pretty tight, but I did drill a hole from the engine compartment and put a brass sleeve and plug in.
    perfect ,thanks
    Valley Center Ca
    No problem. One was a 76 like yours.
    Cut a hole in the front bulkhead and pulled the foam out.
    was it wet ?
    Valley Center Ca
    No completely dry.
    Put a piece of carpet up there for a little extra storage.
    Also partially inflated a tube just in case
    Surprise, AZ
    Stop cutting up perfectly good boats... Lol...
    Senior Member applekrate's Avatar
    Maricopa & St Johns, Arizona
    My Rogers is a '74. I guess I best check mine too while the engine is out.
    www.pontiacheaven.org
    '72 Hondo Flat
    '74 Rogers jet
    Phil 2:11
