1500hp 428 SB Ford - Twin Turbo - impressive
Results 1 to 7 of 7
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    Default 1500hp 428 SB Ford - Twin Turbo - impressive
    This is impressive, even for a Ford. The torque this thing makes is amazing.
    How do you think the numbers would compare with the single Vortex blower on the same motor?
    Video: A 1,500 Horsepower Small-Block From Nelson Racing Engines - Dragzine
    I think I need a moment...................
    S CP
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    S CP
    Real nice Gene, now you have got Jon all worked up in a frenzy and his poor wife is going to have to deal with him the rest of the evening
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by Slow Burn View Post
    Build-for-build and boost-for-boost, the turbo motor would have a handful of hp more than the supercharged version. Of course, nothing is free, so turbos do require "some" hp to run them - but not much. A centrifugal supercharger would still require crankshaft hp to turn it and make boost.
    Therefore, it would still be attainable with the belt charger, but would require additional PSI of boost to overcome the parasitic hp loss.
    Senior Member stoker2001's Avatar
    Folsom,Ca
    S CP
    ditto
    4 ponys per inch and drive it everyday and its old school (block/heads anyway)
    need to win lottery soon
    Whacker Smacker M/E #561 IHBA "first looser"champ 2006&2007&Sportsman Driver of the Year
    Bakersfield, CA
    Nelson sure can tune an EFI TT setup. A/F ratios were spot-on. Turn-key and idles like a stocker.
    Ada, Michigan
    That really shows that a turbo/efi 427 CI small block is all that would ever be needed for an open dragboat. Less weight than a BBC and it would have multi fuel capability too.
    The mirror image turbo's looked nice but I bet the cost was significant.
    Off the shelf cheap diesel units make more sense to me and would be easily available.
    Nelson does a real top quality job.
