Running a Mercuiser hydraulic pump
Results 1 to 14 of 75
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    Default Running a Mercuiser hydraulic pump
    Does anybody know about putting restricters in the lines to run the diverter? If so what is the drill size to drill them out?
    Q.C./Big River
    Quote Originally Posted by PlacecraftTunnel View Post
    PM Bob Prigmore then let me know what he says. I think I'm going to one of those pumps too.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    or just call b1 and they can hook you up with one ready to go
    Q.C./Big River
    Frank, I talked to Jett Marine and Dan said bring them on by and he will take care of us.
    Wittmann,Az
    Quote Originally Posted by HBInHeat View Post
    Do you know how much Cris selling them for?
    I do not but i.do know he sells them and the one i saw at his shop had a nice mounting bracket and an fittings ready to go. Call him tomorrow
    Senior Member bp298's Avatar
    LHC
    i -think- frank's only talking about restrictors, not the whole unit.
    i got mine from tom peterson and he set the whole thing up. works bitchin...
    Wittmann,Az
    Nice, is this a Bennet pump or Mercuiser pump? I bought a mercuiser pump i wonder if he will do a trade then?
    Wittmann,Az
    Yep that is right Bob i picked up some set screws i just need to know what # drill bit to use.
    Senior Member Recycle Performance's Avatar
    Not all the Merc pumps are the same. Most likely you have the incorrect unit. I make them for B1 and Petersons and we do not run restrictors. You may be able to run them that way, never tried it. Just wanted to clarify that we don't set them up that way. They may look the same externally, but there are several different units available.
    Bob @ BJ's Marine - Recycle Performance
    Hi Performance Rigging, Pre-owned and New Parts, Jet Drive Specialists, Powerdcoating, Wire Looms, Gauges, you name it, we can do it.
    Located in Anaheim CA. 714-630-3905. Contact: Bob Jeanblanc, email: [email protected], Website: www.marineiw.com.
    Here's one just finished for Peterson's
    Quote Originally Posted by Recycle Performance View Post
    Bob what does this unit weigh?
    Thanks Chuck
    The one pictured is roughly 8.5-9 lbs. I have a new unit I'm building that weighs 6.5 lbs and I'm working on a newer unit that will be 5.5 lbs. The 5.5 lb unit may be a ways out still. The 6.5 lb units are available now.
    Q.C./Big River
    Will these pumps plug right into a bennet wiring harness or does the whole system need to be rewired? I am definately interested if it is a plug and play as a bennet replacement. The one I have would need too much modification to be worth it at the price you sell them for. Thanks.
