Intake fins...
Results 1 to 14 of 27
Intake fins...
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Intake fins...
    or skegs or whatever they are called. My left one has apparently taken some serious abuse over the years. It has some nice chunks out of it. Neither of them are smooth and could use some filing. Just wondering, can they be repaired or do i just need to find/buy a new intake?
    Lexington, KY
    Exclamation
    Yes, they can be repair. But, if you have to repair any major damage on one of them, then you have to take the same amount off the other on.
    I made a template of how much I was going to take off the damaged one, then just transfered it to the other fin, then carefully trimmed it with a cut-off wheel, and rounded the edges back to how the rest of the fin is.
    Good luck.
    HJ
    Member bennyb's Avatar
    Mission viejo,ca
    My son (BrendellaJet) and I are doing some re-powering on my old eliminator.
    We pulled the pump and one of my fins had a substantial gouge. Jack at MPD welded it up and reshaped it. The cost wasn't all that bad either.
    Go on get your ass outa here
    Senior Member Xerophobic's Avatar
    Calgary, Alberta, Canada
    Intake fins? We dont need no stinking intake fins!
    If you ain't hittin bottom...you ain't jetboatin!
    East Side
    Good topic. My pump is missing about 1/3 of one of it's intake fins. I bought it that way and never had any problems with the boat so I left it. It just snapped off clean. I'm debating whether to weld it back to original, or cut the other side down. Any thoughts? What is the concept behind the fins?
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Quote Originally Posted by Some Kind Of Monster View Post
    they help keep the boat tracking straight and help the boat from spinning out in a turn.
    [quote=Shaun;204621]quote]Unless your running over 80 due the best you can to fix asnd Have fun.
    San Clemente, Ca
    I dont want to cut the fins down, that seams like a bad fix to me. What i was thinking is what Eliminator Cruiser said and build it back up and reshape.
    San Clemente, Ca
    I'll be running over 80 if i'm not already, last gps i ran 76.9 and my foats where set way too low so it was stumbling at full throttle. I got that problem resolved and this last time i went out the boat pulled way harder and felt alot faster, i forgot my damn handheld though. Right now i'm running a berk A imp, no shoe, no rideplate, no setback, no loader, stock rock grate so i'm guessing i'll be in the 80's once i start workin the pump more too...
    We'll see what i'm running this next trip.
    Lexington, KY
    Can we see some pics of what they look like? Because if they're just dinged up a bit, then it would probably be better to just hit them real quick with a sander. For just one chunk, like I had, it was easier to just cut a small portion of the front edge off, maybe not the ideal fix, but I bet it won't make any difference in how the boat will act. But, if there are several chunks missing, then welding would be the preferred method of fixing it.
    HJ
    San Clemente, Ca
    Lexington, KY
    Lightbulb
    OUCH!!!!!
    Looks like somebody hit something.
    I'd be half tempted to make a template of the good fin, cut out the fin shape,
    cut off that beat up fin, and weld the new fin on in it's place. That would help with the breaking problem because it would be billet.
    But, otherwise WELD IT UP, back to where it used to be, then grind it all back down smooth.
    HJ
    San Clemente, Ca
    ya, i'm not sure how they got that way, were talking about a intake thats probably the original intake in this boat, i know it hasnt been removed for the last 15 years, not sure before that.. the boats a 76.
    Senior Member CHEVY JET's Avatar
    St. Charles, IL
    It Is Aluminum, Call A Welder With A Tig And Get A File And A Grinder. Once You Get A Couple Of Passes Grind It Down And Do It Again Until It's How You Want It. Use The File At The End To Fine Tune. Good Luck It Can Definetly Be Saved.
