Battery pics
Results 1 to 9 of 9
Battery pics
    Denton, TX
    Default Battery pics
    I'm redoing my single battery and cables and just looking for some ideas. Thinking about running an ON/OFF switch but thinking it might not beneficial. Also I have about 15 ft extra of 1/0 wire, is this sufficient for cables? My battery is up under the transom so those of you who have it there pics much appericated.
    Thx
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    Below are pics of how I did mine. Made a simple tray with platform for the perko switch. All hidden under the back seat.
ID:	182374   Click image for larger version.
ID:	182375   Click image for larger version.
ID:	182376   Click image for larger version.
    2011 Rouse Performance 19'
    WFL Crew
    SDBA #819 vdrivegrimes's Avatar
    Oct 2011
    I would add a master on/off. Ive walked out in my shop before and my fuel pump and bielge pump where on. Water got the toggle wet earlier that day. If i had a master kill it wouldnt have done that
    Quote Originally Posted by 72Hondo View Post
    Thx
    Do you mean 1/0 cable? If so that will work fine. I don't have a pic, but always try to go as short as possible on the pos cable to the starter and to your 12v power feed to the rest of your system. The longer the run the more voltage drop and the higher resistance in the circuit.
    Denton, TX
    Yes it would be 1/0 cable. The PWR and GND runs are short less than 2 ft. I was looking for just clean install pics of those of you running batteries up under the transom.
    For cheap cable go to your local welding supply.
    member
    Nov 2008
    Thumbs up
    Quote Originally Posted by Alter Ego View Post
    Clean boat, clean instal!
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Thx
    Quote Originally Posted by sandeggo View Post
    Even cheaper is using the cable he already has.
    Massachusetts
    Those switches are obsolete. Use one of these simple battery mount ones instead. A lot cheaper ($6.00), no holes to drill, no cable needed, no switch mechanism to fail, no key to lose, and more current because of less resistance.
    Top Mount Compact Battery Disconnect Cut Off Switch | eBay
    Real Boats Don't Have Propellers!
    -- Rivernut
