Clearance ??? on the Pump
Results 1 to 14 of 21
    Mar 2010
    Clarksville, TN
    Default Clearance ??? on the Pump
    Hey guys could some of you pump gurus please explain what is the proper way to measure and set your pump clearances.
    If you have a couple different impellers to try out, what is needed to be checked before you install the impeller ??
    Pics are always welcomed
    Saw a video one time by Berkeley that showed how to do it. Impeller to suction housing clearance. More to it than just that and I'm by no means an expert whatsoever
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Industry secret. Hush hush.
    Dec 2009
    Northern Indiana
    You can go to cp performance website and check out the manuals listed there. Youtube has some pretty decent videos too.
    Chantilly Va.
    Quote Originally Posted by Chop Shop View Post
    Hmmm, thats exactly what I was thinking this morning when I read this question. I just didnt have the balls to say it.
    Mike, to try to exchange impellers make sure that they are of the same size, not stating the obvious but know the difference/tolerances of the skirt-wear ring area. lay the impeller on a known flat surface and measure the over all height and check for differences. to see if there will be a difference of how far it will seat into the wear ring take a measurement from the outer height of the wear ring to the nose or hub of the impeller. this difference will determine to add or remove shims on the shaft. also watch for the difference on the tail of the impeller so that it wont hit the inside of the bowl. will take some exacting measurements, hope this helps.
    Mar 2010
    Clarksville, TN
    Not lookin for any secrets just the how to. I gotta good pump man, it's just been dead in here and I'm sure I'm not the only guy that would like to do this stuff the right way
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by johnray069 View Post
    That's the info I'm lookin for, thanks Johnny
    Iuka, Mississippi 38852
    whats the ideal measurement between the wear ring/impeller and the impeller/shoulder? isn`t there a thrust/bend factor and does the material used for the wear ring have to be taken into consideration?
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by Richard Till View Post
    That's the secret shit Richard, were not allowed to ask that
    I dont have the equipment to check my stuff. Outta curiosity...if a fella wanted to check his clearances. What would be the money best well spent.
    I guess you need a large mic to meas the impy....can the same tool meas the wear ring?
    I dont now how too loose is..... I can tell its time to go through my pump again.
    Slippin outta the hole....lost 5 mph....ect.
    How tight is too tight?
    Kreg without getting to elaborate with your tool investments You could spend a few well spent bucks to purchase a 9/12 inch dial caliper for your purposes and measure your impeller skirt, however it would likley be less effective to try to measure your wear ring (shaft in) Your impeller (if standard) should be 7.225 , W/R should be 7.250 "contrast" is .025.Your "tire spin" could be several different things Tom
    Check out Starret brand Dial Calipers
    Thanks Tom. My pump has seen some abuse. I will look at that link.
    If someone wanted to tighten up a pump....what increments do wear rings come in.....cause mine is gettin lose.
    Btw...got my diverter cable today....thanks
    Typically in increments .005 os but you would want to asess (and measure) the impeller first and Thank you ! Tom
    Mike sorry for the thread tangent !
