Lighting header question
Results 1 to 3 of 3
    Slimp-O slimp-o's Avatar
    May 2011
    Chimacum Washington
    Default Lighting header question
    Are Lightning headers like Bassets, where the water is injected into the header once the pressure has opened the valve? Or does water go threw at all time?
    San Diego, CA
    Quote Originally Posted by slimp-o View Post
    All the time. Water jacketed. Not injected. Water doesn't mix into the exhaust stream until after the collector. The bassetts inject right at the beginning of each primary pipe
    Boat 405.
    May 2011
    Chimacum Washington
    Ten four, thats what I was thinking. Thank you...
