Bottle placement question
Results 1 to 11 of 11
    Default Bottle placement question
    So will it be alright if i place my bottle this direction?
    Will it affect my nitrous shot under acceleration?
    Trevor.
    Be one cold foot if that regulator breaks
    Quote Originally Posted by sandeggo View Post
    Been like that for 2 years now, just facing the other direction.
    I wanted to turn it around so i can read the PSI and turn on while driving.
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    Trevor.
    The bottle has a suction tube in it running to the bottom of the bottle and curving toward the bottle outlet, running it like that the liquid will uncover the pickup tube, in other words it won't work that way.
    Why don't you try mounting the bottle alongside the seat on the outside of the seat, just a thought
    Quote Originally Posted by FARMER JOHN View Post
    I want to move to the outside of my seat but dont want to drill holes through the bottom of the boat.
    Anza Valley, Lost Lake, CA
    You could maybe fab up a mount to go between the stringers.
    Tempe/Big River
    i like mounting them back near the motor/exhaust. keeps the bottle temp up and consistent
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    I made a platform that my billet bottle mount was bolted, later welded to that holds my bottle beside the passenger side seat. I can see the psi gauge, and the bottle is angled right. My platform has a 2" angle piece welded on that bolts thru a side support of the hull. I have seen others bolt a sheet of aluminum under a seat that sticks out enough towards the side so the bottle bracket can be bolted to it. Just ideas...
ID:	184186   Click image for larger version.
    2011 Rouse Performance 19'
    WFL Crew
    Quote Originally Posted by white tortilla View Post
    yea ok..maybe ill make a mount that adapts to the valve cover and header and put the bottle inbetween, that should work great..
    Quote Originally Posted by Alter Ego View Post
    Good idea, thanks.
    Where did you get your front seats, David and I are thinking about going that direction.
    Jun 2010
    South Arkansas
    Scott Seastrom from Scott's marine. His wife maggie does the stitching, he makes the shells. It is the nicest interior I have ever had, real quality stuff.
    WFL Crew
