Bowl bushings
Results 1 to 3 of 3
Bowl bushings
    Senior Member obie's Avatar
    Feb 2009
    Default Bowl bushings
    I was trying to put the kids boat together but the bushings fall right thru the bowl, any thoughts? Split bowl.
    At the end of the day do u really wanna be seen driving a wacker?
    B1 Racing cs19's Avatar
    Quote Originally Posted by obie View Post
    Happens quite a bit.
    Bore is likely damaged and oversized for one reason or another.
    A good fix is a sleeve in the bore.
    B1Racing.net
    corona calif
    Default Bowl Bushings
    With that much movement in the pump what does the end of the shaft look like. Wasn't the impeller damaged also from hitting the ware ring?
