General Drive Questions
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 49
    Dec 2010
    Question General Drive Questions
    Forgive my boating ignorance please. What makes a V drive all that? From what I have gathered its a motor a gearbox and a prop. The drive shafts connect the motor to the gearbox and the gearbox to the prop?
    To the uninformed (me) it seems like an engine/tranny/prop would be the same. I have no agenda here I just don't get it. I am rebuilding a boat and thought that Jets might be an awesome way to go. Of course I dont want to give up speed. I want my cake and all... The boat I'm building is a 36' offshore boat.
    I was at the Key West Worlds and I didn't see any jets on those boats that were my size. They all looked like the motor/tranny/outdrive type. Even the turbine powered boats.
    Is this a size or weight thing or drag racing only thing?
    Again, I have no agenda other than to learn more about this sport I love.
    Dec 2010
    Question
    Nobody has any input at all. Did I cross some line here?
    New here Beer:30's Avatar
    Bakersfield, CA
    Did I read right that you want to run jet drives in a THIRTY SIX FOOT boat? About the biggest boat for jet propulsion is 26 feet. Even that is way inefficient.
    The reason V-drive or outdrive or outboard power is better than jet is positive displacement - a prop actually grabbing water and propelling the vessel. A jet is pushing water to push the vessel.
    A 26' boat with 450hp and jet would probably top out at 45-48 mph.
    The same 26' boat with 450hp and outdrive (or pobably even V-drive) would be a 60-68 mph boat.
    Think of it as the props actually applying the HP to the water. The jet is applying the HP to the impeller, which is only pushing water through an orifice. That water (pressure) pushing against more water just slips and never actually "grabs" to propel the boat.
    COHETE ROJO velomax's Avatar
    Sep 2010
    NM
    No line crossed, just to much info to be put into 1 reply, all of your question have been answered in one way or another, if you search the threads you'll find answers. P.S some of the cats on this forum are good at posting links to those threads, maybe they'll chime in.
    Sent from my electric web watchin tv thing.
    Aug 2009
    Fox Valley Wisconsin
    If jets are so inefficient ,why do some very large ships use them.
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Quote Originally Posted by BAJA JA View Post
    Very LARGE boat moving SLOWLY. Two key words. Large and slow.
    large ships don't use jets for propulsion. Steering and manuvering, yes. But not for propulsion.
    that would depend on the size of the jet wouldn't it.
    BTW, worst discription of a jet I have ever read. HP in the water VS HP in the impleller. Really? That's the cause of the jets limitations?
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    ...That water (pressure) pushing against more water just slips and never actually "grabs" to propel the boat.
    In this thread's scenario, No argument, props would be more efficient than jet drives plain and simple
    But with all due respect, I believe your "explanation" is misleading.... water pushing against water is not the physics behind aquatic jet drive propulsion. If this were true, a jet boat with the place diverter full up would have zero forward motion as all of the water is pushed into the air. Aqua jet drives develop propulsion via Newton's 3rd law: "for every action there is an equal and opposite reaction"
    At low speeds, the jet drive is more efficient if the nozzle is exiting at or below the water line as the "lake water" offers only minimal restriction to the low mass and velocity of the water exiting the nozzle and the "lake water" actually aids as a "push board" to the opposing forces. But at high speeds, the "lake water" acts as a restriction to the water exiting the jet thus reducing the mass and velocity inside the jet drive itself. Therefore, at high speeds the jet drive is more efficient when the exit nozzle is raised above the water level.
    [QUOTE=SNiC;1752716] If this were true, a jet boat with the place diverter full up would have zero forward motion as all of the water is pushed into the air.
    [QUOTE]
    Really? Directly into the air from the nozzle? Just water shot into the air moves the boat along? Like shooting a fire hose from the top of the transom.
    I think you tried to convince me of that once before.
    Just water shot directly into the air.
    Apr 2011
    Sweet Home Alabama
    Quote Originally Posted by SNiC View Post
    I am saying NO! The water shooting into the air or the water is NOT what is "moving the boat forward", nor is it the the "water shooting against water" is what is moving the boat forward........that is what Beer30 is saying.
    However, if you attached a fire hose to the transom facing backwards, and pushed water through that hose at high volumes, YES, the boat would be moved forward....
    [QUOTE=SNiC;1752769][QUOTE=gn7;1752759]
    I agree with you! Maybe you should read my post again......
    Really? Then what is.
    Apr 2011
    Sweet Home Alabama
    [QUOTE=gn7;1752773][QUOTE=SNiC;1752769]
    Are you thinking of thrust as in a Jet Aircraft turbine?
    [QUOTE=SNiC;1752776][QUOTE=gn7;1752773]
    It has to push off against something. Its not magic.
