shaved bowl???
Results 1 to 5 of 5
shaved bowl???
    Aug 2009
    Default shaved bowl???
    i'm lookin at a g bowl that has had 1/8 machined off the entrance side of the bowl.is there enough internal clearance for this? what about the depth of the threads...any ideas/or theory ?????Click image for larger version.
    B1 Racing cs19's Avatar
    It moves the veins and surface where a stuffer bolts up closer to the impeller. Alot of shops used to do this.9 times out of 10 the machinist that did the work didn't quite have a handle on what he was doing and it didn't get done correctly. It can be checked to see if it was done right, also the wear on the bushings is a way to tell if something isn't right.
    B1Racing.net
    If the bowl seal looked torn up after being ran, check that the threads on the pump shaft for the impeller nut didn't get into the seal. Happens alot on stuff that's been shortened.
    Bowl bolts should be ok, might need to bottom tap the holes, don't run a short bolt, use factory length bolts
    B1Racing.net
    Nov 2012
    i'm curious as to what you mean by that? As in he took to much off or milled it off center or?? Seems to be with a G bowl it pretty much straight forward....a C well not so much.
    be safe , frank.
    Quote Originally Posted by frankeerizzo View Post
    be safe , frank.
    Meaning machined incorrectly. That machined face must be perfectly square to the bore where the bushings are.
    B1Racing.net
