Comp Cams Belt Drive 6200 Issues
Results 1 to 13 of 13
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Comp Cams Belt Drive 6200 Issues
    November 27, 2012
    The problem I have is the replacement seals for this belt drive don’t fit. I ordered some from Summit Racing and the order shipped from Comp.
    The replacement Cam seal diameter is too small.
    Has anyone had this issue?
    Willis
Name:	Cam Seal too Large.jpg
    El Cajon, Ca.
    Where's the orange hammer?
    Actually, I haven't bought a new seal in a couple months, but the last few I got fit just nice. Do you happen to have the dimension of the bore of your part? Perhaps it was a bit on the wide side.
    The Bostick®
    B1 Racing cs19's Avatar
    Willis, go to a seal supply and get one there, take the parts with you and have them cross reference, that seal doesnt look like anything special from what I see. I see the "CR" on the seal, probably a common seal.
    B1Racing.net
    Gardena, CA
    Default CR 21069 usa
    The seal has this number on it CR 21069 USA
    Gardena, CA
    six,
    What was the part # and the color of the seal?
    Take that to a seal house, they will set you up. Willing to bet its not a special seal.
    B1Racing.net
    LINK: Common seal specs and part numbers
    From the pic, I would say a 21101 is closer to what you need. But thats just a guess looking at the pic.
    Gardena, CA
    Default COMP CAM New Part # 6200CS2-1
    November 28, 2012
    Thanks people,
    Comp Cams has responded with this info:
    Upper Cam Seal for #6200 & #6300 (2 .770" O .D .) = 6200CS-1
    Upper Cam Seal for #6200 & #6300 (2 .845" O .D .) = 6200CS2-1
    The new part# is 6200CS2-1
    It is larger than the 6200CS-1
    We have them in stock.
    __________________
    Matt Maxwell
    Technical Consultant
    COMP Performance Group
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    The orange hammer is the seal of approval, judging from the pics I have seen in the past...
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Senior Member kdub's Avatar
    Houston
    Chicago Rawhide would be the seal manufacturer
    Gardena, CA
    Quote Originally Posted by 2002CP19 View Post
    We're working on the hammer
    El Cajon, Ca.
    I figured it was a deal like the American Choppers guys, where everything gets a whack from a hammer. Seal? No Problem... got a hammer for that. Bolt? No problem... got a hammer for that. Toggle switch? You guessed it... Hammer Time! I swear those guys must have had an entire roll-away tool box full of different hammers to beat shit together with. At least Willis just has the special orange hammer.
    The Bostick®
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by willis View Post
    working on it???? willis, you didn't break the hammer too, did you??? don't tell us... the anvil's next on the list??
