[Question] what brand of boat is this pls?
Results 1 to 14 of 24
    Nov 2012
    Default what brand of boat is this pls?
    bought it a week or 2 ago and i found one that looked identical to me when i did a google search and now i cant find it to show the mr. the one i thought it looked like had something like montego in the name. any help would be great thanks.
    Senior Member wolfie's Avatar
    What does the registration number start with? What are the first three letters?
    Nov 2012
    as far as i am aware it doesnt have any numers. i am in new zealand, apparently boat was from usa at some stage so unless they have numers stamped into the hull somewhere i havent seen anything to ID it.
    Senior Member namba860's Avatar
    Las Vegas, Nevada
    looks like a kona to me
    Nov 2012
    thanks, i'll search that and see if it looks same.
    corona calif
    Default 18 Kona
    Quote Originally Posted by wrinkley View Post
    Looks like a 18 Kona, probably in the mid 70's. It seems to me there might even be a set of molds somwhere down under. I know there is a set of Eliminator 18 bubble deck molds down there somewhere , shipped in country in the late 70's
    Nov 2012
    thanks, can anyone tell me if they have numbers stamped into them anywhere and if so where i would generally find them? its just a hull, no controls or anything so if it would of been on them then i guess i wont find them.
    As your standing behind the boat...generally on the right side of the transom. Welcome to the madness
    Nov 2012
    thank you, i'll go have a look...
    Just below a rub rail if it were to have one on the right like mentioned above...Could of been painted over so look close with some light.
    Made In The Shade
    Custom Window Tinting
    Nov 2012
    i cant see anything so will show this to mr when he is home and get him to look.
    Tower Park Resort, Lodi, CA
    Oct 2010
    661 So. Cal.
    Just looking at the rear of the gunnels and transom area, my guess would be a Kona.
    Las Vegas, Nv
    That is either a Kona or Tahiti.
    Does the boat have full stringers, or 1/4 stringers? If full stringers, it is more than likely a Kona. If 1/4 stringers it could be a Tahiti.
    The Tahiti Tiger came first and the Kona was a direct splash of the Tahiti. All Konas had full length stringers, at least here in the States.
    Here is a picture of the Kona that I built. http://www.performanceboats.com/jet-...-build-ii.html
