swtd rebirth
Results 1 to 14 of 24
swtd rebirth
    Aug 2009
    Default swtd rebirth
    1980 swtd found me.pretty much complete overhaul.do i cut the pod half off? what type of loader/intake will get me started.where should the engine be placed.its gonna be a two seater.dominator pump.where should the pump be?half or full set back?.and no idea of what kind of power will find its way into this boat..any bottom mods for this hull???i saw some fins that bolted to the side of the tunnel about the last two feet maybe air trapping aid???any thoughts will be helpful....thanks in advanceClick image for larger version.
ID:	185575Click image for larger version.
ID:	185576Click image for larger version.
ID:	185577Click image for larger version.
ID:	185578Click image for larger version.
ID:	185579Click image for larger version.
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    I Just finished up on a SWTD. Maybe give this a read http://www.performanceboats.com/jet-...nel-build.html
    And dont cut the pod!
    If ya have any questions feel free to send me a P.M.
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    El Cajon , Ca
    It sounds like all of you questions are dependent on your one variable! You need to decide how much power your gonna throw at it in order to answer all the mod questions.
    Woodstock, IL.
    Looks like alot of work. Always good to see another TD coming back to life. Good luck.
    What is that in the background?
    The government's monetary role is to maintain the integrity of the monetary unit, not participate in fraud
    Aug 2009
    tx19 in the garage
    Senior Member papaletch4130's Avatar
    Jul 2010
    Good luck that is about where my swtd was when i started.. Its a long road..lol
    Senior Member Mouzer's Avatar
    corona ca
    i sold 2 swtd to tommy papp and the first thing he would do is cut 1/2 the pod off..why was that ?
    ''''''OWNER OF THE BIG WHITE WOLF....,,,
    Aug 2009
    prolly my two biggest questions would be 1. cut the pod or notClick image for larger version.
ID:	185587 2.how far back with the intake....currently the intake hole is one inch from the transom
    Sep 2010
    From what all the SWTD guys told me when i put mine together is. Don't cut the pod and leave the intake where it is.
    Pm Futs. He will set you in the right direction. His family owned southwind.
    corona ca
    ya wheres that "FUTS" dude
    Senior Member bp298's Avatar
    LHC
    1. no.
    2. it's fine where it is.
    that said, i've never really seen anything quite this messed up. obviously, the stringers need to be replaced. but it looks like somebody took a router to the tunnel tops??? why would somebody do that??? it looks like you'll need to get that front bulkhead out to replace the stringers correctly. you also need to do some work on the transom and around the pod corners, as they will flex and crack if the corners aren't strong.
    since it's completely dismantled, if you really want to go forward with this, i'd try and see how much it weighs like it is. weigh the trailer by itself, then weigh it on the trailer. or vice versa.
    considering the shape it's in, i'd strongly consider cutting the cap off to work the inside of the bottom. it is a mess, and is going to need a lot of grinding, sanding, and new glass.
    did you get -any- pieces/parts with this thing, or are you starting at ground zero?
    LHC
    Quote Originally Posted by Mouzer View Post
    it exposes the bowl, and can allow installation of a popoff. but i changed impellers many times over the years and never found it such a pita that i'd cut the pod for the tradeoff. i also ran mine over 100 many times, 111-112max, and never felt the need for a popoff.
    the riding surfaces (flat areas next to the center keel) extend to the end of the pod. so when you cut the pod, you're cutting 5-6" of riding surface, which is going to reduce keel lift. there are ways to try and compensate for that, but that was always my concern when thinking about it. i still wouldn't do it.
    We passed on buying this one recently (very rough) but you"ll note similar plates to what I belive your describing thru bolted to the tunnels Tom
    1. no.
    I'm thinking maybe they were going to do balsa floors and so they "notched" the tunnels and the center sponson to lay the balsa laminate in.
