Place diverter nozzle angle tool
Results 1 to 7 of 7
    Dec 2010
    Sapulpa ok
    Default Place diverter nozzle angle tool
    Does anyone sell a tool /spacer so you can square to the nozzle bushing to use an angle finder to set the nozzle angle on a place diverter FTN ?? I can make 1 but if they're cheap I just thought I would buy 1 ??????????
    Senior Member wajetboy's Avatar
    Auburn, WA
    yes darin at whiteflagracing.com does,
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Senior Member bp298's Avatar
    LHC
    mpd makes one. been using it for 15 years. call jack.
    Tempe/Big River
    x2 MPD makes a simple lil bitchen aluminum one
    Jun 2011
    spokane, wa
    As wajetboy said contact Darin at Home Page for the one posted above, bitchen little unit!! Chris and Jordan from B1 use the same one as well.
    Ada, Michigan
    I used a digital inclinometer. It was about $ 180.
    You can 0 it out on the keel and either put it up against the end of the nozzle or lay it inside.
    Great tool for setting up many things on the boat.
    Senior Member bc18's Avatar
    B1 carries them.
