SWTD Seats
Results 1 to 10 of 10
SWTD Seats
    Member 1980condor460's Avatar
    Newcastle
    Default SWTD Seats
    How do you guys have your front seats mounted? I am in the process of replacing mine and am going to replace the home made bracket to secure them better. Does anyone make a stringer mount specific for this setup?
    Thanks!
    Senior Member Futs's Avatar
    Orange CA, Big River
    i just used 4x4 angle. cut to fit, trim and powder coated. I intergrated them into my cross section beverage holder
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    i used two 3 inch aluminium angle about 10 inches long for each seat=bolted to the stringers then seats to the angle
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Quote Originally Posted by justsquirtin View Post
    X2
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    1.5" x 1.5" aluminum .250 angle across the tops of the stringers, with 12" x 4" aluminum .250 plates bolted to the stringer.
ID:	186568Click image for larger version.
    Newcastle
    Default Angle
    Sleek - my setup was similar to yours in concept - not even remotely close in the looks or functionality department. On mine the angle was simply sitting on the stringers. I didn't like that. Very interesting. I like the idea of adding a plate between the seats for cup holders........
    Tim's setup with the cup holder is very clean. Doing something similar on mine but will have a little recessed compartment for little things.
    Senior Member papaletch4130's Avatar
    Jul 2010
    I have a rear bench out of a swtd if anyone needs one.
    Fiberglass?
    Jul 2010
    It's wood.
