puke tank mount
Results 1 to 14 of 21
puke tank mount
    Senior Member almost busted's Avatar
    Sep 2012
    MN
    Default puke tank mount
    hey guys just lookin for some opinions on were to mount my puke tank.low or high on the back of the scoop? It would be alot easyer to fab up the low mount. but if put it higher I may need a secondary brace to keep it sturdy. But the breather would be it the wind a little more blowing any smell if any away. has anyone mounted there puke tank like this on there scoop if any could you post a pick Thanks
ID:	186903   Click image for larger version.
    Senior Member lupo1904's Avatar
    Feb 2011
    I would fab up some brakets and mount it on the ski tow.
    Team CJ460 Just Electric's Avatar
    granada hills
    That's how I have mine mounted
    Heres a couple ideas for you Bud
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    We just mounted ours to the top cap opening in the back with the thin metal brackets that come with them.
Name:	As of 9-1-11.JPG
    QE 439 Twin Turbo
    Mar 2010
    Clarksville, TN
    Kinda goin through the same thing here on my boat .. Is it better to mount them hi or low ???
    Good lord that looks mean
    New Port Richey, FL
    It's fairly ferocious. One more puke tank pic.
    QE 439 Twin Turbo
    Senior Member bp298's Avatar
    LHC
    doesn't really matter. if it's higher, it's a bit easier to check/drain anything collected.
    Senior Member Sweet Pickle's Avatar
    Mar 2011
    Calimesa CA
    Default Breather
    Pan Evac system into the headers simplifies the system if the headers are running dry. JMO
Name:	Nicks Misc 009.jpg
    Dec 2010
    Sapulpa ok
Name:	cheauto race 008.jpg
    Sep 2012
    MN
    THANKS GUYS!!!!!! for the ideas. I pulled out some scrap I had this is what I came up with so far. Im not sure if its thick enuff but it may work.I have to fit the gussets and maybe drill a hole in them before they get tiggwelded. What do you think?
ID:	186976   Click image for larger version.
ID:	186977   Click image for larger version.
    Sep 2012
    MN
    Quote Originally Posted by Sweet Pickle View Post
    I did have evacs on headers but Im putting shotgun tips on and I guess if you run water you cant have evacs on the headers with the shotguns. I might need to push water through headers to pass the D/B test the water cop is gunnin for me and I want to pass!!!!! so after about $1500 in parts + my labor I hope my changes work. I will post more pics as I go with the up grades.
    NW Boater racemonza's Avatar
    Dec 2010
    Bonney Lake Wash
    Default looks Good ...Nice Work
    Quote Originally Posted by almost busted View Post
