flat side gullwing???
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 44
    Aug 2009
    Default flat side gullwing???
    um, have i heard this phrase? " flat side gullwing" .mine(firehawk) seems to be angled in more at the bottom.narrower running surface.than say a mantra or others?are a few inches wider over all. so ,is there a running difference ? is one faster or safer or ???.....
    Anza Valley, Lost Lake, CA
    Is it flat or wavy? Straight or angled?
    Senior Member Sharkbit's Avatar
    Jan 2010
    I think it's called a narrow cockpit TX19.
    Senior Member TrollerDave's Avatar
    Chino,CA
    I think you're talking about the vertical sides of the hull.
    If so, the 18' has more vertical than the 19'.
    If you're looking at the boat from the bow,
    18' = l v l
    19' = \ v /
    If you understand my babbling , is this what you meant?
    Dallas, TX
    I know the Earl Smith gull wing has straight vertical sides. There are several variations of the gull wing out there.
    Q.C./Big River
    There ARE several variations out there but really only two designs. One with straight sides and transom= 18' gullwing, one with angles sides and transom=19' gullwing. Whether it is a mantra, earl smith, CP, youngblood, scorpion etc, an 18' bottom and a 19' bottom are the same design no matter who had them layed up. The decks are really the only thing that change. Not the sides and transom.
    Senior Member bp298's Avatar
    LHC
    huh???
    the cp 18' has flat sides. the whole boat is smaller, not just the deck. the flared sides on 19s provide much more cockpit space than an 18.
    the bottom's of every gullwing ever laid up are not identical. i've been told by someone who knows that there are subtle differences.
    here's a cp 18 with flat sides.
    here's one of tigerfang's 18s (not cp) with flat sides. while these things look similar, they are NOT identical, top or bottom. they are not set up the same way, and one wouldn't necessarily work well at all with the other's setup. but both do work, and work well.
    Tempe/Big River
    the "flat sided" gullwing is gonna be probably a CP whereas an Earl Smith or Youngblood are considered "wavy sided" gullwings. haha
    Q.C./Big River
    huh???
    Yes!!! 18' gullwings have straight up and down (basically 90* sides) and the 19' gullwings have angled sides. And I never said that they were all identical. I said the 18's from X,Y,Z builder are the same design and the 19's from X,Y,Z builder are the same design. 18's have straight (90*) sides and 19's have angled sides. Where did you read that I wrote they were all identical? Of course the small details like keel, intake placement and hardware will all be different but the design of each boat, 18 to 18 or 19 to 19, is the same. The pictures you posted prove my point. Both of those boats are an 18' and they have the same 90* design on the sides built by to different people.
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default smith or Youngblood
    If its a 18' gull wing with flat sides it is a copy of an Earl Smith if you look from the front it will have a Texas longhorn T on the deck. Repeat 18's are Earl Smith splashes. If it's a 19' gull wing with a flat deck it is a Jim Youngblood or copy. I believe Jimmy Johnson was the one that splashed the YB and gave it the bubble deck. If that Green boat in the picture is Carr's boat it is a Scott Seastrum version of an Earl Smith. The CP 18' tunnel is a copy of the Earl Smith 16' tunnel that had a 18' V nose top put on it I think by Mantra, Sunkisst or Greg High I forget. The Earl Smith 18's except the first couple had no wood in the transom some may have a drop or bubble keel but they are ALL Youngblood or Earl Smith copies
    LHC
    well, when i read this... "Whether it is a mantra, earl smith, CP, youngblood, scorpion etc, an 18' bottom and a 19' bottom are the same design no matter who had them layed up" it seemed to me you were saying they were all the same... "identical". i'm talking about differences in bare hulls. saying they're all the same is kind of like saying all 18' shallow v's are the same. they are not all the same.
    Quote Originally Posted by vmaxed View Post
    yes it is my friend greg's boat. and i already said it's one of tigerfangs. the cp 18 tunnel is NOT copy of something else. that mold was created with nothing splashed, other than the cap he already had.
    personally, i could give a crap who theoretically copied what. irrelevant.
    edit.. meant to say 18' tunnel
    All 18ft gullwings had wavey sides untill about 91 when Scotten made a new mold and took the waveness out.
    Q.C./Big River
    yes it is my friend greg's boat. and i already said it's one of tigerfangs. the cp 18 is NOT copy of something else. that mold was created with nothing splashed, other than the cap he already had.
    Ok
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
