Best pump
Results 1 to 14 of 19
Best pump
    Banne'd Cobra1's Avatar
    Default Best pump
    So who makes the best pump these days? Or are they still using the same old things they made 20 years ago, no improvents to any of them?
    Senior Member lupo1904's Avatar
    Feb 2011
    Water pump, oil pump , concreate pump, dick pump, jet pump which pump are you talking about
    Well since this is the jet section,I'm going with jet boat bump. Berkeley,Dominator, AT, Legend,Hamilton/kodiak, Scott?
    Mar 2010
    Clarksville, TN
    The best pump is a Tight pump
    Senior Member yardsale_03's Avatar
    Jul 2009
    I got a set back pump
    Feb 2011
    How about a fist pump
    Senior Member Lildave's Avatar
    Aug 2010
    Bauxite, AR
    2 pump chump?
    Feb 2011
    These work really well with an inducer and a loader
    Senior Member TrollerDave's Avatar
    Chino,CA
    Quote Originally Posted by lupo1904 View Post
    Dude, I was just thinking that before I scrolled down
    Happy New Year's Eve Cobra1. You might get a more serious answer tomorrow
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Late model dominator would be a good start
    Jul 2009
    I would use whatever you or your builder is most comfortable with.
    I think the doms flow more
    Dec 2010
    Sapulpa ok
    If U want a good pump plan on spending around $1500 or more on detail work inducer ect. That's if U have a ss impeller to work with.
    Quote Originally Posted by Psycotic Break View Post
    That would be me, new 20' in the mold. Just toying with the idea, not sure what way I want to go as far as drive unit.
    Aug 2010
    Bauxite, AR
    I'm no expert, but I know you'll get better info if everybody knows a little more.
    Type of hull?
    HP?
    RPM?
    Goals?
