loader trim or not???
Results 1 to 3 of 3
    Aug 2009
    Default loader trim or not???
Size:  23.8 KBthis is an mpd made for my gw.it sits at 1/2 below keel right where the pen is.any thoughts on this depth.35 pounds of intake pressure at the top and bottom taps.any thoughts on cutting it like an arrow.thanx in advance
    San Diego, CA
    Rather than trimming your good MPD loader, see if you can loan a loader with the change you want to try before you cut. Loader tuning can be very fruitful if gone about methodically.
    Boat 405.
    Senior Member bc18's Avatar
    Mine hangs that low also
    I have that exact loader. Pretty much have to trim it back a little and see if you pick up any on your low side.
    I know jack has a test loader that is shorter than that maybe he'd let you try first before cutting yours down.
    Another thing is not only the ramp length but where the ramps are angled towards the impeller.
