Something is off?
Results 1 to 14 of 29
Something is off?
    Mar 2012
    San Tan Valley AZ
    Default Something is off?
    I dont think my boat is running the correct rpms for my setup. I have a fresh jacuzzi wj w/ an b impeller snd a 460 bored .030 with keith black dish pistons. Ported d0ve-a heads, stealth intake. Trick flow pushrods with comp roller rockersCrane 288 commander cam. 850 dp. Msd distributor with a msd box. It only turnd 45-4600 rpm max. Problem id I was turning that before when it was stock. I have swapped tachs already. What could be the problem? Camshsft timing maybe?
    "Im Too Drunk To Taste This Chicken"
    Sep 2011
    Los Angeles
    Quote Originally Posted by mygarageguys View Post
    Good chance it could be a timing issue.
    Close to the water...
    That would be the first thing to check for sure
    Put a degree wheel on it and get your cam card out
    Lot of mistakes happen on the 429-460 here
    Mar 2012
    San Tan Valley AZ
    Ok so it does sound off then. ill check it out.
    Need more info!!! Hull type, weight, loader style if any?
    Senior Member brgrcru's Avatar
    Montrose
    X2
    Quote Originally Posted by brgrcru View Post
    X2
    I agree.
    Lets try to be realistic here. If the timing is off due to a "replacement" timing set that has a retard built in it like most "replacement" Ford sets do, and the OP didn't use a name brand performance T set, what is the very very best super optimistic RPM gain you could expect to see if the timing was "corrected"?
    Remember, MOST el cheapo replacement sets retard the timing which isn't exactly detrimental to turning RPM.
    I wonder what pie in the sky RPM the OP was hoping to turn.
    What do you honestly predict this motor should make for horse power and where is it (peak HP) made (RPM) given the combination you have described and assembled ?
    Orlando.FL
    4500 -4600 sounds about right for the setup you have.
    I agree.
    Well Bob, in under a half hour I could top stop the piston verify cam timing and have a TDC mark to set timing from
    Its just a starting point for me. Before chasing my tail. I would verify the basics are in place first
    Seen a few people f- up multi key timing chains in the past or had the dampener slip and the timing marks are off when setting the dizzy
    Things that you are supposed to catch when building the motors vs assembling parts and hoping it works out
    Oct 2010
    Lake Dallas TX
    I thought with Ford's you just throw some parts in a box..shake it and run what comes out?
    California
    Was the pump rebuild with the engine rebuild? If it was fairly worn prior to bebuild, tightening up the pump likely countered some of the rpm increase you would have seen with the added HP.
    Mar 2012
    San Tan Valley AZ
    It is a 21 omega open bow with fresh jacuzzi wj. No loader.has Pd. Ride plate. Also the timing set is a cloyes double roller with 3 keyways set. Just seems off. Alot of money in the motor with no gains. Expected hp is 450ish. Btw I am running logs.
    Mar 2012
    San Tan Valley AZ
    Pump was rebuilt during the rebuild. I am looking for 5100 rpms ish. Is my setup capable of this? If not I believe my cam is the limiter. What do u guys recommend
