Fuel cell for small jetboat?
Results 1 to 12 of 12
    I'm baaaaack... hkunz's Avatar
    Lake Havasu
    Default Fuel cell for small jetboat?
    We have a 16' Tahiti, and with the 455, the 12 gallon tank just barely makes it from gas dock to gas dock. What have other folks done to increase the amount of gas they can carry? My current tank is steel, 19' wide, 16' deep, 12' high. The tank width is about 17' because the pinch welds on the ends make up the other two inches. We are thinking of either or both of two things - a larger fuel cell/tank under the bow where the original one is, and/or a new, additional cell between the rear seats to augment the first one. Ideas?
    It is impossible to defeat an ignorant man in argument. -William G. McAdoo, lawyer and politician (1863-1941)
    07 Advantage X-Flight 600 SCi Bravo 1 XR
    04 Cheetah Scorpion 6.2 Bravo 1 - SOLD!
    96 Donzi 21' 454 Bravo 3 Medallion - gone!
    72 Tahiti 16' 468 Olds Berkeley jet - SOLD!
    11 RZR XP, 08 Polaris Scrambler, 06 Rhino, 06 Joyner 650 dune buggy, 04 KFX 700
    Senior Member milkmoney's Avatar
    vegas
    Quote Originally Posted by hkunz View Post
    ya i am with you on that, i only have two 11 gals and at wide open its a gallon per min.. i cruise 3000rpm with a double pumper and go up the river to parker dam and its about empty on one side.. i would like to also have some info...
    Lake Havasu
    I found a fuel cell on Summitracing.com that will fit between the rear seats and add 12 gallons. Seems like a lot of work for not much more gas, AND, it'll take up a bunch of room.
    vegas
    ok i will go take a look, i dont use the back seats really. thanks for info..
    vegas
    i agree way to much work...can a guy get bigger tanks to replace where the current ones are???
    You really dont want to put a larger bow tank in that little deep-entry 16' Tahiti. It will just aggravate the tendency that hull has to bow-steer. If anything, try to find a set of saddle tanks that will fit.
    vegas
    i have saddle tanks now in a 19' bahner and like i said they are only 11 gals each side, could i put bigger ones in,,??
    It's good to be alive
    Lake Havasu
    with those dimensions you should be at 27,200 gallons....floating should be the issue
    I never hit bottom. 79Challenger's Avatar
    Quote Originally Posted by franky View Post
    Now that made me laugh... It wouldn't be a jet boat, but a jet tank!
    Tacoma Wa
    Quote Originally Posted by milkmoney View Post
    That is some terrible gas mileage man!
    Lake Havasu
    Inches, feet, potatoe potato LOL
    vegas
    Quote Originally Posted by LuckyDaze View Post
    ya i would like to hook up with some folks and go over a few things on my jet, maybe i am doing something totally wrong..its been a while since i have been around jets ,,it sure drinks the fuel..i am kinda confused on the amount of fuel it takes..
