machining shaft for inducer?
Results 1 to 10 of 10
    Default machining shaft for inducer?
    are these the right deminsions for the dps inducer? i pulled them offa the dps site, but on other pumps i've worked on or built , the key way for the inducer was opposite of the impellor key. so do i cut the keyway for the inducer inline with the impellor keyway?
Name:	inducer shaft.jpg
    I don't have my instruction sheet here at work but my new shaft from MPD
    has the keyways inline.
    Lurker
    NC
    New shaft from HTP came with them lined up.
    Tom call my cell I'll fax the specs and diagram Tom
    i may just yank it out next monday and send it your way tom, i can get it done locally but if they screwed the pooch, i wouldn't make the races on the 4th
    lol, right..... Devilman's Avatar
    South Texas
    Don't forget about set screw placement....
    Quote Originally Posted by Devilman View Post
    done, i got a nice shiney philips head ss bolt to put in it
    those are the correct dimensions as furnished with the dps inducer and the billet inducer. most will cut the key ways in line as you can use the impeller key to locate off of for the centerline. i have cut several, by request ,with the key way 180 degree rotated from the impeller. had an engineer tell me that this was stronger but i don"t know. anyhow i have several want the key way rotated, just a thought. tip. if not running a lot of coolant watch out cutting the shaft as it will grow from the heat, leave a little extra for the final grind and be sure the shaft has cooled down.
    Quote Originally Posted by johnray069 View Post
    thanx for the info john! i've got access to a nice lathe and i could cut the shaft but the end mill my uncle has isn't to par so i'm gonna just send the shaft out and have it done. i'd hate to phuck up my own shaft
    if you need, i can cut it for you same day and return, have my own cncs,pm or better give a call 423-252-7249 usually have the cell phone on.
