Chub Tub Update 2
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 49
Chub Tub Update 2
    Senior Member stc315's Avatar
    Yuma, AZ
    Default Chub Tub Update 2
    Dropped Weiand Stealth intake and Berk droop at polishers. Ordered pick up from Rex for the Dooley pan and also a nozzle gasket. Ordered loader from Chris at B1 (very excited about this part). Once I get all the parts, I'll pull the motor to fix some leaks and install intake, pan, and loader. Will take measurements and angles so B1 can build a shoe at that time. Then I need to save up for new gauges, fuel sending units, and flush fuel fills. I've been told the fuel fills are notorious for letting in water so I'll have a water separator to the fuel system. Not sure if I should put it before or after filter.
    Too much horsepower is almost enough!!!
    My boat is fast.....on Craiglist or EBay.
    I've been 340mph+ with a boat........In the back of a C130!
    Dec 2010
    Sapulpa ok
    Before the filter.
    Senior Member TrollerDave's Avatar
    Chino,CA
    Is this a Placecraft?
    Did you get the hull buffed out yet? I was looking at your first thread that you posted when you got it.
    That you pic you posted (your avatar) looks sweet.
    Good luck.
    Yuma, AZ
    Quote Originally Posted by TrollerDave View Post
    Good luck.
    It's a Baker. Similar bottom and deck. Not buffed, pic was taken after a rain storm lol. Still need to sand it and clear coat.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Quote Originally Posted by stc315 View Post
    LOVE the "Chub Tub" name, bout used it myself...
    yes water separator before the filter X2 on what Piston said
    My experience is fuel fill is the same, have had several boats, but depending on location of the fuel fill, if the hull design allows some water to build up around the fills then yes extra precaution is advised (gasket under the fuel fills and TIGHT fill necks) if you dont have a bunch of in and out, sitting on the sides, and keep and eye on it, water going in will not be an issue, also I like the Flip Tops better for keeping water out than the others that the caps screw in.
    Yuma, AZ
    I thought about aircraft style but venting them would be a pita.
    Sent from my DROID BIONIC using Tapatalk 2
    Yuma, AZ
    Default Refinishing Project
    The original gel is beat from the sun. I got the idea of re-clear coating the top half. 1st attempt didn't go so well. Got it sanded down and took it to my buddy's shop to shoot clear. It was a beautiful day and the shop was full so we shot it outside. Driver's side came out great, but by the time I got around to the passenger side there was a small amount of dust in the air and it was attracted to my boat lol. Sooo time to sand it back down.
Name:	Boat Finish Project 001.jpg
ID:	234586   Click image for larger version.
Name:	Boat Finish Project 003.jpg
    Yuma, AZ
    After wet sanding with 500, I rinsed it down and shot a couple of pics of it wet so I could see what it will look like with clear.
Name:	Boat Finishing Project 2 001.jpg
ID:	234602   Click image for larger version.
Name:	Boat Finishing Project 2 003.jpg
    Yuma, AZ
    I have a couple of places that need to be sanded a little deeper and then it's back to my buddy's shop to try again. This time, the shop will be clear and we can shoot it indoors. I also found out we were running too much air pressure, had real bad orange peel effect. His compressor regulator is set at 110psi!!! I've got a small pressure regulator that mounts to the gun and I will dial it down the 40psi this time.
    okie, lake Texoma
    Damn, that wet sand/buff really brought it back. Looks great, keep up the good work!
    H8-2-W8
    [email protected] first pass
    Yuma, AZ
    It's actually water lol. Hosed it down and shot the pic. Hopefully I can get clear to look that good.
    Very Handsom Hot Rod Sammy ! cant wait to see more
    Yuma, AZ
    Thanks Tom, it's getting there. Now if I can only get the clear coat to come out like it looks wet with water lol. Thanks again for the helm. I was expecting a used one at that price!
    Maple Ridge B.C. Canada
    do you have the jet intake out?
