Header Injection, anybody use these?
Results 1 to 14 of 29
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Header Injection, anybody use these?
    Wondering if anybody used these and what kind of experience they had with them? My boats headers i think are running a little more wet than they should be, i'm just looking to get it perfect. I'm thinking about buying a set of these and just drilling them out if i need more flow.
    hole is 0.125"
    Please dont say install a gate/ball valve, i know thats what alot of you do, i'm not looking to go that route.
    Clovis, Cali
    If those go on the water lines to the headers, Yes, I use something very similar. I have never heard of anyone else running them . When I bought my headers (in 2001) I was told to do it that way by one of the local old timers, have never had a problem, and they still look great !! I just check them before I go out to make sure nothing plugged up the small holes. As far as the hole size I don't remember what size I ended up with but my pump is a Jacuzzi YJ and doesn't make as much pressure as a Berkeley style pump.
    San Clemente, Ca
    They go into the primary feed of the water injection lines for each header.
    Clovis, Cali
    Yep, that's where mine are too. I just took a cordless drill and the set of drill bits with me to the lake and kept drilling them out until everything looked right. As I said they have been that way since 2001 and here's a shot from a this year (still looking good) .
    I've gotta say Propless's setup is what I would call perfect. You see absolutely nothing coming out of the pipes while cruising. When you really get on the throttle you'll see nothing but a big puff of steam come out and that's it. And his headers are 5 years old with only the area between the heads and the weephole blued.
    Have used something like those for about 18 yrs on the CP. Work just fine.
    Sleeper CP
    Ladera Ranch
    You could always save your money, weld the holes up on the header fittings and re-drill with a much smaller hole...
    San Clemente, Ca
    Those restrictors i posted are like 8 bucks each
    Ladera Ranch
    Sorry, I just try to fix things that I can for free rather than throwing more money at it...
    San Clemente, Ca
    I'll agree with that!
    The Right Coast/SE-PA
    Actually what I did and (several others)...tap the header/fitting hole for a small brass screw, grind off the head and drill the size needed. Works great!
    Rollin With Fink fasterthanu's Avatar
    Norcal
    I used holley jets in a few boats, just tap the hole and you can try various sizes....
    Senior Member Futs's Avatar
    Orange CA, Big River
    Or just run them dry and be done with all your headaches....
    San Clemente, Ca
    rex sells jets in different sizes for these too, says to drill and tap them for the jet size. He has 3 different sizes. I'm going to order the -8 restrictor above, we'll see how well it works.
