Mounting side tanks
Results 1 to 14 of 18
Mounting side tanks
    Aug 2011
    placentia,ca
    Default Mounting side tanks
    What is the best way to mount side tanks into a light layup daytona 19. I have a couole ideas but I wanted some opinions. The tanks are 8" Russell stainless.
    Apr 2012
    Tucson
    I remember seeing an article about glassing in a bracket, I'll see if I can find a link. Hate seeing holes drilled through bottom.
    Apr 2012
    Tucson
    Link is an article it of hot boat mag. Found some pics on SoCal. About half way down some images of the article.
    http://www.socaljetboats.com/hulls/saddle-tank-mounting/msg156748/#msg156748
    Did your boat not have side tanks before? Tanks in my Ultra through bolt from the bottom through the hull. I think the are 3/8" tapered and counter sunk so they're flush on the bottom. Not big on through bolting through the hull but other than glassing in mount plates, I don't think you have many options.
    My swtd has the standard stainless brackets. It's a pain in the ass to get to the back bolt. I'm either gonna tack the nut to the bracket or make some tapped aluminum bases kinda like a ride plate cradle.
    Aug 2011
    placentia,ca
    Sam sent me some pictures awhile back that have an aluminum "h" bar with studs then glassed in the boat. That link to scjb shows a hot boat article with the same brackets. That's what I had in mind the whole time. I was curious if I could use wood as an alternative but I have no extra room
    member CONCEPT MARINE's Avatar
    Montclair, Ca.
    Default tanks
    Quote Originally Posted by SofaKingFast View Post
    we did the tank mounts in Mikes boat. (cyclone)
    CUSTOMER & QUALITY SERVICE ARE NUMBER ONE
    Senior Member CP598's Avatar
    Sep 2008
    Mine has wooden blocks glassed to the floor, with the tank brackets mounted to the wooden blocks.
    Ladera Ranch
    In my last boat I glassed 2 bulkheads in on each side, with a round hole in each. I put carpet on each side of the bulkhead and that in conjunction with the fill tube held them (TANKS) pretty snug. Worked out well.
    Anaheim Hills
    Mine are the same way.
    Dave these are the ones I welded for Sam. He glassed them to the floor.
    Sorry but it's the only pic I got. Sam may have some
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Drill holes in the bottom or the inside of the tunnel
    I have hard time drilling holes in the bottom of boats, so I would glass the brackets in, wood could be added
    Aug 2011
    placentia,ca
    Quote Originally Posted by sandeggo View Post
    That's what he sent me. That's what im going to do.
    The strap connecting the two pads together is unnecessary but it doesn't hurt. It does help keep things lined up while grassing the mounts to the floor.
