Feeding a bullet/surge tank from saddle tanks?
Results 1 to 10 of 10
    Sacramento area
    Default Feeding a bullet/surge tank from saddle tanks?
    Can anyone explain how to get the fuel from the saddle tanks to a bullet/surge tank with out over filling it? And if you do over fill it, how to get it back to the saddle tanks evenly?
    I plan on running electric pumps to fill the bullet/surge. Mechanical to the run the engine EFI. EFI Returns to the saddle's.
    Thanks, be safe. schick
    Senior Member K-034's Avatar
    Mar 2012
    I ran return lines back to the saddle tanks, I had one -10 in and two -10's out on this boat never had a issue with it
    Atlanta, Texas, United States
    Quote Originally Posted by schick View Post
    Another method is to mount a carburetor float bowl or two to the bullet/surge tank. Use a large needle and seat. Works pretty well as long as you do not feed the engine with more fuel than you are feeding the tank for a long period of time.
    Sacramento area
    Quote Originally Posted by Gearhead View Post
    Yes, I considered that. I'm going to need about 7gpm. I don't think the floats will keep up?
    I guarantee you that 2 of these bowls with .130 needles will keep up with any engine you'll be feeding and any pump you plan to be hooking to them.
    Keep in mind that even though the pump is rated at 7 gpm, you do have a bypass going back to the surge tank. Thats no indication that your engine NEEDS 7 gpm. Far from it!
    On this Lake boat we built special saddle tanks with -8 returns, -8 feeds and bung fills in them , fed the bullet from the block mounted mechanical Holley, then ran fuel continuously gravity draining back from the middle/center of the bullet to the saddle tanks , fed the Enderle pump with gravity from the bottom of the bullet (-10) and siphoned off fuel from the bullet also to a electric tickler (for starts) will find more pics if your interested Tom
    Sacramento area
    Thanks for the input GN. Your right the engine won't need 7gpm.
    Thanks again, be safe. schick
    Close to the water...
    Default Diamond marine
    Diamond Marine, outboard racing engines, mercury outboard racing
    Check out fuel systems 101
    lots of good info here
    Sacramento area
    Thanks Tom, I'm thinking of feeding the bullet with electric pumps straight to it (no regulators) Then gravity back to the saddles. My concern is over filling one of the saddles.
    Did you find the Dominator reverse bucket? I have one.
    overfill really shouldn't happen (tecnically) with the "calculated" system assuming the tanks drain and re-fill equally , we didn't use an electric feed as we ran a Mag and no charging system
