need advice on a 19 cp
Results 1 to 6 of 6
    Oct 2012
    Default need advice on a 19 cp
    I have a 400 lb cp with mersch intake, berkeley jet with stainless a, 500ci bbc (800hp) and 2 buckets. I was wondering where do i set the ride plate and nozzle to. Also how long of a driveline and how much shoe should i use.
    Senior Member lupo1904's Avatar
    Feb 2011
    Do some research in the jet boat section or the wfl section, find a good starting point and run with it, see what it does. I found alot of good info on this forum. Good luck its only time an money
    Feb 2012
    OC, CA
    Its not how long of a driveline to use, its how far forward is the engine set. We have our engine set at 25" from transom on our 18, per MPD. Not sure on a 19. Hardware is all test and tune, one change at a time. Start with 2 to 4 degrees on ride plate.
    Anza Valley, Lost Lake, CA
    Quote Originally Posted by lupo1904 View Post
    "It's Only time and money" lol. I like that.
    corona calif
    Default Intake
    Quote Originally Posted by garrett'scp View Post
    Are you sure that you have Merish intake in a 19 CP. Unusal to have a low profile intake in a 19. Don't get me wrong there are low profile intakes that are being used in the 18 but not many in the 19. Shoe depth , nozzle angle, and rideplate are all going to be different on the low profile intake. The pump is going to load harder than what is being used in the majority of 19's being run. Most are running a modified 4 degree so shoe depth is going to be different alnog with nozzle angle and rideplate angle.
    Senior Member bc18's Avatar
    Call Chris at b1 racing (949) 294-1394
