Going to logs from ot headers
Results 1 to 3 of 3
    Jun 2011
    Default Going to logs from ot headers
    • I have a mild 454 with over the transom headers. I will be going to logs with snails. I will be running the supply water from the pump to the logs then to the block and out each side of the themostat to each snail. My question is do you still throttle the water from the pump like with the headers or do you leave it wide open or is that to much? Do you possibly leave it wide open and run another dump line? I just want to make sure I have enough water flow so that my exhauts hoses do not melt and I end up having a very bad day. Thanks for the help.
    Quote Originally Posted by Larry13 View Post
    Your log plumbing and flow are different from Headers for sure , the plumbing routing you descibed is somewhat correct your water flows from the jet to the manifolds then to the lower block (adjacent to the timing cover] , then out of the water divider on the intake (Tstat hsg,no Tsat) then to the snails , no outbound metering like the headers use ,This would cause the connector hoses to burn and could sink the boat call or PM if you need help tom
    Jun 2011
    Default headers to logs
    pm sent
