Rental Mock-Up Cam Idea
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 47
    A Real Love For Speed Bass Lake Boz's Avatar
    Jan 2013
    Ahwahnee California
    Default Rental Mock-Up Cam Idea
    I have a suggestion that just might promote sales and help the customers also.
    If Brand “X” Cam Company would make a complete set of cam shafts that had only one or two of the cylinders with the cam lobes on the cam so the customer could install this cam for mock-up to see if this would clear the pistons for his / her application.
    These Trial cams could be rented out with a reimbursement IF the customer bought their cam choice from Brand “X” Cam Company. They could rent a selection in the range of profiles that they are considering. Surely they wouldn’t want to keep a cam with only one or two sets of lobs on it. The shaft only needs to be 1/4 length of a full shaft. A deposit that would be refunded would also insure the return of the Mock-Up cams.
    I know I would rent some from you if this was an option.
    What do you think ?
    Boz
    Quote Originally Posted by Bass Lake Boz View Post
    These Trial cams could be rented out with a reimbursement IF the customer bought their cam choice from Brand “X” Cam Company. They could rent a selection in the range of profiles that they are considering. Surely they wouldn’t want to keep a cam with only one or two sets of lobs on it. A deposit that would be refunded would also insure the return of the Mock-Up cams.
    What do you think ?
    Boz
    I think I will do it like I always have.
    Just because a valve clears a piston when baring an engine over by hand does not mean that it will clear when the engine is running. Temperature changes cause parts to grow while RPM and inertia cause them to "stretch". The only true way to ensure that the application has enough clearance is to measure the distance between the piston and valves. There are several methods to do this most of which can be researched on the internet. The biggest thing is to take your time, make sure your numbers are accurate and do your homework as different parts (i.e materials) can run tighter clearances than others. Good luck on the build.
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    Quote Originally Posted by Woods 017 View Post
    Im confused, aren't you still going to check valve to piston clearance before the motor is ever fired? Or are u suggesting check all cylinders clearance?
    Another problem I see with this idea is that this would only work for mass produced cam profiles, it'd be useless to use the 1/4 cam idea if u use a 600 lift 1/4 cam to check clearance, and install a 700 lift. Doesn't seem cost effective to make a custom 1/4 cam every time someone orders a custom cam.
    2011 Rouse Performance 19'
    WFL Crew
    Jan 2013
    Ahwahnee California
    Quote Originally Posted by Alter Ego View Post
    You are right it would be useless to make the ¼ length mock-up cam on custom grinds. Those who do order custom cams already know what will fit. They have mocked up their engine and know exactly what they want. I was intending those who are first time builders or those who are changing the whole set up. Stroke, Compression height & dome cc’s & combustion chamber volume. Checking Cam advance piston to valve clearance during mock up. These would be for those pushing it to the limit on valve lift. I agree this isn’t for everybody and if you have a system that works then stick with it.
    These mock-up cams were targeted towards those who do not have a starting point or a system that works for them. Not everybody has a buddy that has a old cam to check his P/V clearances or the clams to have the experts to do it right for them.
    Besides, I said I have an Idea. I didn’t say it was a good idea.
    Just throwing something out to see if it gets shot down or not.
    Boz
    Boz, I don't think your brillant idea would work to well. YOU may be the ONLY person I know that would buy a cam because it "clears: his pistons, or even avoid a cam because it doesn't.
    I personally buy the cam the engine wants, not what I want, or what "clears" my pistons.
    I assume you are one that picks the biggest cam that fits?
    BTW, I don't recommend you try suggesting this to a cam grinder.
    Jan 2013
    Ahwahnee California
    First of all never assume.
    And I am not trying to just throw the largest cam I can at this motor.
    Just one big enough to make use of the cube’s I’ve chosen. If you really want to give some intelligent advice then will you please let me know What lift cam you would think my 540 ci 14.2:1 comp. 48 cc Domed pistons would want? Could you possibly pass on a name of somebody that could suggest a cam profile? I have been asking for help and so far only one man has told me that the .700” lift cam should fit. But I was the one that suggested the cam lift. Obviously I don’t know what is needed. But so far no recommendation on what lift to use.
    Thanks for your input.
    Boz
    21' Liberator Jet NORDIC454's Avatar
    BIG D
    1/4 Race cam!
    Put clay on top of piston and turn motor. Then you will know how much room you have.
    Just one big enough to make use of the cube’s I’ve chosen. If you really want to give some intelligent advise then will you please let me know What lift cam you would think my 540 ci 14.2:1 comp. 48 cc Domed pistons would want? Could you possibly pass on a name of somebody that could suggest a cam profile? I have been asking for help and so far only one man has told me that the .700” lift cam should fit. But I was the one that suggested the cam lift. Obviously I don’t know what is needed. But so far no recommendation on what lift to use.
    Boz
    That’s just how GN7 is. From what I’ve read on these forums he is a VERY knowledgeable guy when it comes to BBC's.
    He can help you but you got to get through his sarcasm first!.
    I wasn't being sarcastic. I simply do not get the idea of a "mock up" cam. You cam the engine, and you MAKE the thing work. If you don't care to fly cut the pistons to make the REQUIRED can work, then you appearently are willing to leave power on the table. Most modern pistons will clear whatever cam 90% of the non race boats need anyway. Most race engine builders are not concerned with fly cutting pistons to make the RIGHT cam work in needed.
    Boz
    First, lift is never the problem, duration, LSA and installed intake centerline are. I have a .775 cam that clears stock off the shelf JE pistons, and a .720 that requires fly cutting the same piston, and both cams are ground by the same company. Others that clear the intake fine, but the exhaust needs flycutting. But I never changed my mind about the cam because it required cutting the pistons.
    Did you ever consider the effect the rod ratio has on the valve clearance with a given camshaft?
    Not to mention how far in the hole the piston is at TDC. If the heads are 24* or 26*, if they have a 2.19, 2.25, or 2.30 intake valve.
    So I recommend a cam and the pistons need fly cutting and then you're pissed off because you wanted a cam that "cleared"
    Way to many varibles to say what will and will not clear unless you're more than willing to leave some power on the table due to a "safe guess", not whats RIGHT!
    Quote Originally Posted by NORDIC454 View Post
    1/4 Race cam!
    That would be my "safe guess"
    What do you think ?
    Boz
    Boz, there's really no market for this. I understand your thinking, but the fact is, there are just too many different cam profiles for this to be of any real practicality. Cam cores are expensive and no one is going to take the time to grind four different grinds on a cam, then cut it up, face the front journal, drill it and tap it for the timing set, etc. etc., just to set it on the shelf and "hope" someone is going to rent it. Also, as was said earlier, the engine needs the cam it needs...it's up to the engine builder to accomodate the cam as far as making sure things clear. When you run into valve/piston clearance issues, it's usually an upper-level build and the engine builder should know this ahead of time and prepare for it. Besides, if the cam doesn't clear for some reason, you don't change the cam, you correct the clearance -if- you're doing it right.
    JMO
    Boz
    JMO
    Damn you have become such a SMOOTH talker since your relocation. Did Chris send you off for some etiquette training?
    I haven't relocated yet. I'm practicing.
