What alternator is every one running on their BBC's.Will any automotive alternator work regardless of Year?
And what about starters with a rail kit? will a regular starter work ,without clearance issues? Thank's .....Hal
I use a marine alternator in chrome finish, it came from ARSMARINE.COM . I believe it was only like $100. The starter is a high torque mini starter for a car and it fits with my rail kit.
For the best reliability and longevity you should run marine starter and alt. My starter is a new marine and is smaller than a car starter. My old starter got wet from the weep holes on my headers and gave out. The new one has lasted me three years without fail! You shouldn't have clearance issues with the new smaller high torque starters, I am not sure on the alt. Hope that helps.
I have a regular stock GM starter and it fits my rail kit just fine. For a cheap alternator I have used GM alternators with a built-in regulator (3 wire), I think they come in cars and trucks from around 1975 to maybe 1988. I wire them up as a one wire alternator.
I could be wrong, but I thought starters and such that are rated for marine use were rated that way so they could be used with an engine cover and are not neccessarily more water resistant than their non-marine counterparts. Anyone know for sure?
I run the Hardin Marine hi-torq mini starter and a 94 amp chrome 1 wire marine alternator. I too fully support running only marine parts in a boat. Regardless of whether or not you run an engine cover, IT'S A BOAT!!! NOT A CAR!!!
Furthermore, I'd rather spend the extra bucks for safety...no price cut is worth risking your life (or the life of others for that matter) over.
ECAE's 2025 alternator is nice
http://ecae.com/alt1.html
to add to what slow said, gas fumes are heavier than air so they will sit in the bilge area when the boat has been sitting. If gas fumes are present and a spark occurs, with or without an engine cover, there's a real good chance of a fire.
In a car, the gas fumes will pass through the engine compartment to the ground and dissipate.
how do you choose the which amp will be the best???
Im running a hi-torque IMI mini starter and a prestolite marine alternator, MSD marine distributor.
