help!! need info on building front engine cover
Results 1 to 10 of 10
    Broke Member monstertahiti78's Avatar
    Feb 2012
    Folsom, CA
    Default help!! need info on building front engine cover
    Tax returns are almost here and im finally ready to reupholster the seats in the boat but I dont have a front engine cover. For safety reasons i think that i should make one. we all know how those "non-boaters" can be. Only problem is that i have no idea how to secure it down. Does anyone have any helpful info on building one and how to secure it? or possibly some pictures?
    Aug 2010
    what is this cover you speak of?
    took 3 seconds to make and it keeps peoples feet and ice chests out of the balancer. i have some 90* brackets that bolt through the stringer. the rest of the motor is fairly non-boater-friendly.
    Quote Originally Posted by ka0tyk View Post
    Is that a cam driven water pump??...guess there is more way than 1 to skin a cat.
    I would put up a pic of my ft. motor cover....but its just my back seat.
    Aug 2010
    yeah... the wife lost her balance getting into the boat and decided to sit on my risers. while they were "cool" as far as exhaust goes, it still burned the crap out of her and so i use the pump to pump fresh cold water thru the exhaust/risers to keep them as cool as possible, rather than feeding off of the dump water after its warmed up to like 200* going through the motor, or tee'ing off the pump water to feed the exhaust and the motor at idle.
    Feb 2012
    Folsom, CA
    Thats pretty much what i was looking for. My seats are a little smaller than yours so i may need something a little bigger but that gives me something to start with. Appreciate the pic
    Feb 2012
    Folsom, CA
    anyone else have any pictures or ideas for an engine cover? Im trying to a few different ideas to work with
    Two quick disconnect pins and unplug the speakers and its out...both the hatch and front cover.
    Made In The Shade
    Custom Window Tinting
    Feb 2012
    Folsom, CA
    Thats awesome. I love the ease of use with that. only problem is that i have OT headers. Will probably go TT at some point then ill be building something like that.
    Surprise, AZ
    Here's mine. It is notched and slides over the stringers. I also have a bulkhead behind it to keep it from being pushed into the motor.
    Feb 2012
    Folsom, CA
    Quote Originally Posted by 67weiman View Post
    Thats basically what I had in mind. Thanks for the info.
