Interior
Results 1 to 14 of 17
Interior
    Jan 2013
    Default Interior
    I'm looking at replacing my current interior with new wood and new upholstery. I've thought about putting in fiberglass buckets rather than wood, any recommendations? If I do go with wood, are there any tricks to the front buckets?
    Thanks,
    Ben
    Lots of Folks are upgrading to Glass Buckets and benches , clean modern look much simpler and cost effective than traditional plywood , our Glass buckets and benches for example weigh less than 50 lbs combined(w/o covers) and are virtually unbreakable , weight savings helps performance ,not to mention the covers can be stripped of for storage simple to install and cover, may not have that classic look but still nice Tom
    Fiberglass is really the easiest way to go. It'll be easier to upholster as well. When I made mine I made the backs with 2 pieces of 1/4" ply. I glued them with waterproof glue, screwed and clamped them like crazy. I made 2 pieces that resembled the bottom piece radius, one for the top and one for the bottom. Once the wood was all dry, I unscrewed it all and the backs were curved. Then I cut the rough shape out with a jigsaw. Then I did multiple layers of cloth and mat in the corners and around the edges. The whole thing got multiple coats of resin. It's a lot of work, but very doable.
    Jan 2013
    I've attached a few pics of my current interior. The way it is set up, I'm leaning towards all wood, but might look at fiberglass for the front buckets.
Name:	boat misc 059.jpg
ID:	212346   Click image for larger version.
Name:	boat misc 073.jpg
ID:	212354   Click image for larger version.
Name:	boat misc 069.jpg
    Senior Member TrollerDave's Avatar
    Chino,CA
    Why do you want to get rid of the front reclining buckets?
    Been there. I blew out the sides of my front buckets.
    I had a shop do mine new interior. I can't remember if it was the old or new interior, but where the back was curved, it had vertical cuts
    every 1" or so. Then it was stapled along the cut on the back side to hold it together.
    Another style is instead of having it rounded, have it curve with angles.
    Where can a get Glass buckets and a bench seat like this?
    I like!
    My interior is HEAVY.
    Aug 2010
    whatever you do, go with a bench in the rear. i did the typical "cocktail seating" that most boats of these years came with and i wish i would have gone with a bench now.
    Aug 2011
    placentia,ca
    I bought a set of carbon front seats from a member here on the boards from canada. The seats are absolutely amazing quality. The price is right and the guy is awesome to deal with. Ill look up his info and post back. Here is what they look like. These are 20" buckets as well.
ID:	212882   Click image for larger version.
    Tom Peterson makes a nice fiberglass seat at a very reasonable price. (626)258-7207. If you are looking for a carbon fiber seat Tony Hammons is the guy to talk to. (928)446-1791.
    Quote Originally Posted by Woods 017 View Post
    Awesome thanks. Carbon Fiber looks trick, a rear bench made out of carbon fiber to match would be the shit.
    Jan 2013
    Is a bench seat worth the lost space?
    Quote Originally Posted by ka0tyk View Post
    Jan 2013
    It makes the interior easy to replace. What does a set of buckets plus a bench cost?
    I like!
    Redding, CA
    I did the swap to bench last year.
    If you haul people in the back seat, remember that leg room will be all but eliminated with the bench.
    BUT, the engine is bulkheaded and MUCH safer for passengers. Trade off.
    I got the glass bench from Tom at JBP, and the buckets from CP, although Tom does offer them also.
    Both pieces were quality pieces, and Tom even channeled the bench for the Miller width.
    Had them covered locally, and fabbed the mounts.
    The old seats, and the typical Jet boat mounting with wood screws, was becoming unsafe as HP and boat speed increases the last few years. My driver seat actually tore out during a spin caused by equipment failure..
    Now I can shake the whole boat and trailer by any seat and nothing gives....MUCH safer!
    The old lounge seating.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Quote Originally Posted by Tahiti76_Ben View Post
    The packages (buckets and bench) weigh approx 50lbs and come ready to upholster, rear benches start at 60 inches and can be made as small as neccesary , front buckets come in 20" and 24" ,I sent you a PM with quote , they are typically much less that the materials and labor required to build them from scratch (wood,screws,glue etc) Tom
    Jet Boat Fiberglass Bucket and Bench S, Jet Boat Performance
