wiring color code
Results 1 to 14 of 19
wiring color code
    Senior Member slotracer's Avatar
    Default wiring color code
    i know its on here somewhere does anyone have the color code to wire a boat? cannot find the one i printed out
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    Boats N Hoes Brad22CP's Avatar
    Northern Cali
    Quote Originally Posted by slotracer View Post
    We have some info on our site that should help you out. Look on the bottom right of the page http://www.cpperformance.com/Instructions/default.htm
    Good luck,
    Brad
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    purple = eng
    black = ground
    gray = tach
    brown = sender
    green = lights
    Red = Hot( battery)
    shot me a email if that dont help ya, not sure what you are trying to wiring!
    Newton Ks.
    A partial list.
    Standard Boat Wiring color Codes.
    Blk -Grounds-General
    Blk/Brn -Pump Grounds
    Blk/Red -Voltmeter Grounds
    Blk/Org -Isolated Accessory Grounds
    Blk/Blu -Lighting Grounds
    Blk/Gry -Nav Light Grounds
    Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
    Brn/Red -Pumps, Bilge or Sump
    Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
    Brn/Wht -trim pos sender
    Red - Battery Feeds Unprotected
    Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
    Pink -Fuel Sender
    Org/Blk -Audio System Feed
    Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
    Yel/Red -Start Solenoid(starting circut), Neutral Safety
    Yel/Org -Powered Ventilation, Fans
    Yellow -Bilge Blowers -(also alternator DC output)
    Grn/Red -Stop Solenoid/Kill Switch
    Green -Bonding
    Blu/Brn -Oil Temp Send
    Blu -Instrument & General Lighting
    Light Blue -Oil Pressure
    Vio -12v Ignition-Generator or Engine
    Gray -Navigation (running) Lights, Tach. Send
    Gry/Wht -Anchor Light
    Tan - Water Temp sender
    Pink -Fuel sender
    H.L. Mencken
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    A partial list.
    Pink -Fuel Sender
    Green -Bonding
    Pink -Fuel sender
    Where can you find the wire in #14 or #16 in the colors mentioned above? I can find red and black in #10.
    Wags
    A partial list.
    Pink -Fuel Sender
    Green -Bonding
    Pink -Fuel sender
    dam i did not know ther were this many wires in a boat. i need just 7 just need to redo the outlaw. someone decieded to use white for ground and red for everything else
    slot
    87 eliminator
    Stockton, ca.
    Cantard 71hallett's Avatar
    snow bank
    I just did mine and used 7 wire trailer wire. Its nice and sealed in a rubber sleve and has a big red and black in it.
    Member TrynPas's Avatar
    Litchfield Park, AZ
    There's a generac drawing that I got on the internet in my album, can't seem to get it posted but I'll try some more later. You can get most of those colors (maybe all) from JEG'S in both 14 and 16 gauge. I got mine from Ebay as a complete set of 16 colors in 30 foot rolls for like $65. I think I searched using 'auto wire'. Here's the company I got mine from (they also sell 14 gauge I think) http://cgi.ebay.com/ebaymotors/16-Ga...spagenameZWDVW
    Litchfield Park, AZ
    Not sure how to post the bmp file containing the schematic. If you can't read it from my album pm me and I'll email it to you or something (unless someone can tell me how to post it)
    fleetimus told me about this yesterday. going to check with napa today.
    slot
    87 eliminator
    Stockton, ca.
    Sacramento, CA, USA
    Quote Originally Posted by TrynPas View Post
    Great source. Thanks
    Wags
    Sacramento, CA, USA
    Find out just how many wires you can get this way. You might consider a hook up trailer wire with 2 or 3 more wires than you think you need just in case, down the road you need another wire or 2, it'll already be there for you to use.
    Wags
    Sacramento, CA, USA
    If you want, you can send it to me and I'll post it up for you.
    Wags
    anybody give any thought to using uscg approved labeled wire for marine application,
