Header Water Line Repair?
Results 1 to 11 of 11
    May 2012
    Default Header Water Line Repair?
    I recently found a pinhole leak in one of my header water lines. How can i go about repairing this without buying a whole new setup?
    I have brazed then before. But most likely they are thin everywhere.
    El Cajon , Ca
    Epoxy putty from your local auto parts store.
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Weld it, braze it, glue it, solder it. Pick your poisen.
    bfp
    bfp is offline
    Top Fuel Jet bfp's Avatar
    ca.
    What headers do you have? Where are you located?
    These are typically Silver soldered (assembly) and can be repaired that way too .... Tom
    bullhead city
    cut it, make a sleeve slide it over the 2 pieces and silver solder
    use a brass compression fitting fast easy repair
    May 2012
    Quote Originally Posted by bfp View Post
    I have Basset Twisty headers and im located in el cajon,CA.
    bfp
    bfp is offline
    ca.
    I have a set laying around somewhere I think.
    Get an 1/8" union swagelok. Done deal, 5 minute repair.
