New project "Mini Baja"
Results 1 to 14 of 33
    Feb 2013
    Default New project "Mini Baja"
    Hey guys new to the forum just thought I would post my new project and say hello. I am working on a 1994 baja blast 14ft had a 90hp force in it and a L drive. I bought the boat with no motor. I had. Older beat up 16ft jet boat with Berkeley jf drive on it. Long story short I am in the process of installing the Berkeley and a 350 rocket olds motor in the boat. I will post pics as I go along
ID:	217202   Click image for larger version.
ID:	217210   Click image for larger version.
ID:	217218   Click image for larger version.
ID:	217226   Click image for larger version.
    Feb 2013
    This all was done in one day Now let the glassing begin the new pump mount and grate is bolted and screwed in several spots now have to glass the f$$k out of it all and shape and finish
    Dallas, TX
    Interesting project. Why the Olds motor? SBC is much more affordable to build.
    Feb 2013
    The olds motor is being used because I already have all the polished manifolds and exhaust for olds and the mild 350 out of the donor boat, going to check clearances re gasket and pop it in. Just thought it would be neat to do the swap checked google and could not find anyone that has done it. The hull seems pretty deep and stable so it should be fun my main thing is everything is neat and done correctly
    Feb 2013
    Dropped my mock up spare engine in to see what kind of room I am going to have and looks like everything is going to fit very well works out great that there is no water pump on the front and only a cover. Will have enough room for alternator and manifolds sure glad that its not a ford and the distributor is in the back
ID:	218082   Click image for larger version.
    Feb 2013
    Mock up engine and exhaust fits excellent
ID:	219002   Click image for larger version.
    deckboat owner rschap1's Avatar
    Lowell MI
    Default wow
    guessing that thing is going to fly
    I had a Four Winns Fling with the 115 OMC in it for a couple of summers
    It will be interesting to see how this thing handles and flies !!!
    Senior Member bartel's Avatar
    Mar 2010
    I like your style. this is going to be one cool little sleeper.
    2006 22ft Placecraft 496 Mag
    Feb 2013
    Thanks guys I'm just doing a lot of glassing right now. It's unbelievable how the engine exhaust and components fit not cutting or not having to notch anything and besides the thruhull it will look factory, re building the engine between glass coats and drying. I am really looking forward to Seeing how it handles and holeshots. More updates after I get some glassing done.
    Hoodys and swim trunks Elkidminoltu's Avatar
    Waterford, MI
    Keep up the work man, looks like a cool project.
    Feb 2013
    I see in your sig your just across the pond from me in Waterford I'm in Windsor. Do you ever run on Detroit river??
    Feb 2013
    First coat of short strand glass and cut in the thru hulls
ID:	220466   Click image for larger version.
    Feb 2013
    Just trying to get the exact shape with a final coat of bondo and spot putty
    Senior Member LIL WAKE's Avatar
    Sep 2011
    Minneapolis, MN
    This is badass man! Very nice work so far! Can't wait to see more. Are you going to repaint/regelcoat it?
    1988 Addictor 333 powered by Seadoo 787cc Rotax (110hp)
