rpm's on 460BBF
Results 1 to 14 of 31
rpm's on 460BBF
    Senior Member 78Eliminator's Avatar
    Default rpm's on 460BBF
    I got a 21 ft Eliminator with a 460 BBF with a dominator jet with it. Does any one know if 4k on the tach is normal for this motor? The jet is a dominator model # MB-12-SAA. Any input is greatly appreciated. thanks in advance.
    Maybe a little low. I've been in a hand full of 18 and 21 eliminators bbc and bbf. and 4500 ish is about it. With maybe the exception of my sisters boat came from eliminator with a healthy ls6. I think my nephews 18 bubble with a bbf runs about 53 mph at like 4400 r's. Motor and pump are untouched sience new 1976 I think. All had berk pumps though.
    ptz
    ptz is offline
    so ca
    Cool
    sound like the pump is good and tight.
    maybe a modern cam would get you some more rpm's.
    Member Jet Hydro's Avatar
    For a STOCK 460 that sounds just about right on the money with a good tight pump .
    Better to be an "Innovator" than a "Duplicator"
    Precision Speed & Marine
    Aggressor Jet Drives
    Senior Member 77charger's Avatar
    about 4400-4500 with a good pump more important what is your speed at 4k rpm?Do you know what impeller you have as well?
    Its been a while since i had a jetboat with a 460 or a 429 it
    Quote Originally Posted by 78Eliminator View Post
    I had the same set-up in 81-88. 1980 Eliminator 21 cruiser- same Dominator pump and a 460 ford. On the tack 4800 RPM and with a buddy that had a speedo that he said was dead on 66 MPH. I did however go thru the motor and freshen up with a mild cam and alittle more spring pressure. Jetted carb to feed the ol mule. Boat was turn key every day I had it a was the first boat my two kids were ever in. Always told myself I would own another of the same and after getting the race crap out of my system for the second time,now do and I will be passing this boat to my kids. Only difference is this one has one of them there tranys and a hangy down part undernieth. FYI the cleceland motors are very touchy to spring pressure and valve train. I raced a couple. M
    Quote Originally Posted by 77charger View Post
    I dont know the speed as i dont have a speedo or gps. Im not sure of the impeller either but on the pump it says its an MB-12-SAA. Dont know if this tell you the impeller. Thanks.
    Quote Originally Posted by Jet Hydro View Post
    Jet thanks for the input. The motor was built by hardin marine. nly has about 15 hrs on it. Any input on what i can do to get a little more rpms?
    Thanks again.
    Thanks Ol Guy, its turn key as well I was just wondering if this was normal. I was running a 454 on my old Bahner and it was running 5500 all day long.
    Thanks again.
    Cam, HEI distributor and most likely a bigger carb. How fast do you want it to go?
    I just worked on a CVX-20 this weekend and it was an all stock 460 with a little 660 carb, ran 4100rpm with an AA impeller. It should run 55 to 60 mph if he keeps his foot in it. With an A impeller he might get 65ish out of it ???
    Im gonna have to save some money and git er done! lol I would like to see 60ish or so on this eliminator. Where are you located?
    Hutchinson Kansas
    Hutchinson Kansas
    A little far to send my boat for you to make it go faster.
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    Where's your location?
